not sure, I seem to remember reading that there is small differance in the bolt pattern with that wheel and the OE WHEEL- will fit but may work loose
just my .02' Johnny
They'll fit, you wont be happy with the way they sit though - see below
These are wider with a lower offset. Those will tuck in a half inch more. If you do get them, you'll want at least a 1" hubcentric spacer/adapter all around
