mechanical oil pressure guage
oh ok i understand what your saying now.. is there anyway i can remove the stock sender completely and just run the line directly to where the sender used to be?
ok cool thanks guys! what about my water temp sensor? the fittin on the sensor is too big for the holes in the head
I suggest staying away from mechanical gauges. They make such a mess if the lines ever get kinked/melted/broken
Autozone sells a copper line kit 4 like $10 4 mechanical oil pressure gauge ,,,,it includes 2 or 3 brass adapters such as 1/8 npt ,,,,,,,,I would just drill and tap the adaptor above the oil filter ,,,,,,,it's the most accurate location that tells You the pressure going to the mains and rod bearings and leave the other 1 as well .
