max effort intake
max effort intake
what intake r u guys running thats cutting these killer times with stock bottom end cars ?
not looking to set a record but i do want to put a good number up on the board.
i will b spraying around a 250.hit
was looking into vic jr and 4150 but i do not want to cut the cowl that bad.
so i am thinking the vic jr and elbow.
what elbow would u sugest ?
Whiteltone has a vic jr, went 9.19@148, and it's been 150.. Carb'd with a plate.. It fit without cutting the cowl too bad, but you would never be able to adjust the rear float bowl. With a 4150 throttle body like Thad, should fit no problem.
