Quench and DCR Question
If you are running dynamic compression in excess of 8.5:1 on 93, what's the ideal quench?
I know lots of the highest dynoing setups have flirted with 9.0:1 DCR but they run Cometic .040" gaskets for quench in the 0.033-.030" range. Stock MLS gaskets are .051" and provide quench in the 0.043-.040" range.
Just wondering if I try to aim for a DCR in the 8.7:1 to 8.9:1 range, should I go ahead and invest in the Cometics too? Or is the cost/prep time unnecessary?
The closer the piston comes to the head without touching the more snap the combustion process has by virtue of atomized compression. This is why direct
injection has soooo many positives. When the piston approaches the head it
causes the air/fuel mixture to violently turbulate and effectively reducing the
BSFC(brake specific fuel consumption)...the number of pounds per hour of fuel
needed to support each horsepower the engine makes. Efficiency.....WINNING
This is one of those things that's essentially free horsepower. Yeah, the GM MLS gaskets are like $40 and the Cometic .040" gaskets are closer to $170, but milling the heads more, going with the thinner gasket, and flycutting if needed will make for more power with all else being equal.
The ideal quench for any application is going to be the smallest You can go without PTV contact . Generally .030" is accepted as the smallest You want to go and have a buffer in the case of spun rod bearing and shutting it down before the bearing gets really bad . Also stretch of the connecting rod and piston and crankshaft are factored . More quench allows more timing /less retard = more power .
Personally i believe you are pushing it at 8.9:1 on 93 pump gas regardless of the ideal quench. Mixtures on pump are not consistent by shipment, store location, or by brand. 9:1 is considered race gas worthy. 8.5:1 has always been the absolute ideal maximum to account for your level of elevation and accounting for atmospheric pressure. If you go to high you will have severe detonation down low or when you cut the motor off which will be an absolute pain to remove without progressively pulling timing.
Aim for 8.5:1 DCR as an absolute max and aim for a quench of .035 to allow for rod stretch to be on the safe side.
Octane boosters do not work because people misjudge the amount you actually need to boost the octane rating efficiently - it is way more than the advertised amount on the bottles.
Torco is just lubricant additives and race gas if i am not mistaken. Same thing as cutting your own mixtures. The problem with this is that you still have the mix of 93 which can still cause detonation. Substituting one for another in a mixture does not work, you need to replace the fuel all together to gain the benefits of higher octane. That is why i said 9:1 is race gas. Not mixtures, additives, cut, etc.
Ill make sure we're clear here and i am assuming you're tuning for optimum performance. If you retard your timing then there wont be any need for it but you lose on overall HP and efficiency. It would be better to use a lower CR and add more timing to make more HP than to have too much and pull timing to keep from detonating. Get stuck in traffic on a hot day and you could be in trouble.
