Lowered
Lowered
So my 98' TA was lowered using Eibach lowering springs to drop it 2" and has Koni fully adjustable shocks all the way around, this was all done by the previous owner.
Any how he also placed 17x11 on the back and rolled the panels. only issue is my passenger side rubs like crazy whenever i hit a nice bump or go over a raised intersection at say 35mph. its not a constant rub, and i found out why...
my passenger side sits lower then the driver side, this lead me to understand why the driverside rarely rubs. now here is the question.. How can i raise the passenger side up.. i need the ammount of almost half of a bottle cap..
i will grap pics in the morning, but on the driver side i can lossly fit two nuckles as to the passenger side i can tightly fit two nuckles...
Summit Racing sells coil spring spacers (PN GLS-1306) that might help. It might be worth double checkig the installation, if you haven't already. Just in case the springs are not sitting in the rubber isolator properly and that they are oriented the same left and right.
Put some bricks around the front tires to keep them from rolling
Jack the rear by the pumpkin
Put jack stands under the rear subframes
Lower the jack so the rear droops down
Since you have sportlines, the rear springs should almost fall out
Hose mod the top and bottom of the passenger side spring
Reinstall and follow the instructions in reverse
could you explain to me how to do the hose method, or is there a thread with pics and all, and do i use a garden hose? lol
sorry bud, just never heard of the hose mod lol, i may run to the store in the morning to grab some
EDIT: after reading a few of the write ups.. the hose mod has seemed to lower the height.. i need the passenger side to go up not down
Or you could ditch the **** springs for some better ones.
You can search for this, but the eibachs for our cars have sagging issues, and the sportlines in particular have some goofy (overly soft) spring rates for the huge drop they give. This leaves you hitting the bumpstops harder and more often than compared to the better springs out there.
Im assuming they are the sportlines since you said its a 2" drop?
i may find someone who wants to trade or will buy my rear springs, i might just keep the 2" in front and do either a 1" or 1.5" in the rear and go with another brand in the rear
EDIT: they honestly look like the Pro-Kit, but the Pro-Kit only lowers 1.0" - 1.5" and the sportlines drop 1.7" - 2.3" but the numbers on my springs match the Pro-kit.
EDITx2: would a panhard bar fix my issue, i still have the stock one.
Yeah im slowling learning that these springs are really soft, i tried the hose mod, i even went to the extent of putting 1/2" hose inside of the 3/4" hose, and 1/2" hose on the bottom of the spring..
Red Eibach springs are Sportlines... Black Eibach springs are Prokits.
No an adjustable PHB wont help with the height issue but is almost required on a lowered F-body.
Instead of measuring with your fingers... park on really flat/level ground and measure from the center of the fenderwell openings to the ground and give us the measurements for all 4 corners.
LS1Tech Premium Sponsor
Ky;e
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
