IDK what the problem is!
Old 12-02-2012, 02:23 PM
America_Owns's Avatar
Default IDK what the problem is!
I drive a 2002 z28 camaro, bone stock to this day. Has a decent amount of miles on it, 115,000 or so and driven hard nearly the whole time. Not much has gone wrong till now and I am not sure what it is.
I was pulling away from a stop, pretty fast, but nothing ridiculous. Then I heard a loud screech and then a loud knock. My friend said maybe I bent a push rod, which is entirely possible with this amount of miles. Or he said maybe the timing got changed somehow, I don't know how that could happen. Any ideas?
Old 12-02-2012, 02:32 PM
slamminjim's Avatar
Spun rod bearing.
Old 12-02-2012, 02:36 PM
Athlon2k2's Avatar
Is it still running?
Old 12-02-2012, 02:49 PM
Received 3,368 Likes on 2,085 Posts
I always hear a loud "screech" when pull away from a stop pretty fast, and then my wife "knocks" me in he head. Happens all the time!
Old 12-02-2012, 03:59 PM
Yeah it still works, but I dont wanna run it. Whats a spun rod bearing?
Old 12-02-2012, 09:07 PM
wildcamaro's Avatar
Spinning a rod bearing is basically ruining the bearing your connecting rod/piston rotates on about the crankshaft...in other words you would need a rebuild...
Is your car an m6 or a4? If its a manual Trans you are more likely to bend a pushrod than an auto since its easier to over rev...
Anyway bottom line is the engine needs to be taken apart to determine the damage. I wouldn't run the engine anymore than u have to until it is looked at. U may save yourself some cash in the long run...have a mechanic or one of your buddies who wrench to look at it
Old 12-03-2012, 01:40 AM
MikeyZ's Avatar
check the oil do you have metal in there? video?
Old 12-03-2012, 02:07 AM
bww3588's Avatar
Putting the cart before the horse a little aren't we? The noises he described could be anything. I don't see any mention of low oil pressure, bearing material in the oil, knocking at idle or anything.
Could have been the rear end, clutch, u joint...etc. things that have nothing to do with the engine.
We need more to go on before anyone can say for sure if the engine needs to be gone thru.
Old 12-03-2012, 02:35 AM
True, while not necessarily a true knock that I am familiar with..it sounds like this: spin a bike tire and lightly set a screwdriver on it. The tricking sound of the screwdriver and the spokes is close to the same noise. The car is an a4. it wasnt very high rpm's when the noise went, only 4-4.5k and red line i sat 5.5k. Rev limiter is 6200rpm I believe. there is normal oil pressure, but it's definitely an engine issue as it gets worse with higher rpm's.
Old 12-03-2012, 02:44 AM
chevybayboy's Avatar
Could have collapsed a lifter can you get a video up
Old 12-03-2012, 02:55 AM
I'd rather not start it again if i dont have to..
Old 12-03-2012, 03:36 AM
That's MISTER MODERATOR
Paul Bell's Avatar
America, welcome to LS1tech!
I agree, don't run the engine and do have a mechanic look at it.
Old 12-03-2012, 04:04 AM
bww3588's Avatar
My guess is needle bearings out of a rocker...
Old 12-03-2012, 10:53 AM
Super Moderator
Reckless's Avatar
Well a loud screech could be a word serpentine belt, it could be a worn pulley as well. Don't assume it is inside the engine
Old 12-03-2012, 12:19 PM
wildcamaro's Avatar
Yea I would at least rule out external factors like u joints, rearend, etc. Before a complete tear down I would at least pull the valve covers and inspect the valvetrain since its easy to do. Hopefully the sound is something up top so you can repair it without having to do surgery.
Old 12-03-2012, 12:33 PM
CHADsterss's Avatar
Originally Posted by slamminjim
Spun rod bearing.
How are you going to say this when you have no clue of what the "knock" or "screech" even sounds like???? It could be a number of things.
____
Post a video, it will help all of us determine you problem... Or at least help us give you some sort of idea of what it is(or might be).
Old 12-03-2012, 12:50 PM
wildcamaro's Avatar
^^^^its "brainstorming" lol otherwise known as "wild guessing"
Old 12-03-2012, 01:54 PM
slamminjim's Avatar
If my car made a loud screech and started knocking than a spun bearing would imediately come to mind.
Change oil and look at drain plug and cut open the filter. Will probably find the culprit.
Hope its not the problem. Just my guess.
Old 12-03-2012, 02:26 PM
FAD2BLK93's Avatar
U could remove the serp belt to elimanate anything rotating in the front of the motor...ie belt, tensioner ect ect, dont run it to long water temp will rise. Does it screech or squeel when u start the car cold or blip the throttle.
Old 12-03-2012, 02:41 PM
Paul Bell's Avatar
.....but it's definitely an engine issue as it gets worse with higher rpm's.
It sure sounds like an engine thing.
Could be something in the belt drive system but...
Get a mechanic under the hood of this car. Don't take any chances of making it much worse.
Quick Reply: IDK what the problem is!
