Procharger questions
Okay I have some procharger questions. Piecing together a kit...
1. With a 6 rib kit is a new harmonic balancer needed? or will a stock or 25% u/d crankshaft pulley be fine? Will the belt run right off the pulley?
2. What all will I need for an 8 rib setup if I were to go with that? Is there a special crankshaft pulley you buy?
What all will I need to complete the kit?
you need a j brakcet , intercoolers, or intercooler , new harmonice balancer for 8 rib , dont go 6 rib , i have it and want to change over to a 8 rib setup .
if you go 6 use the stock balancer and the 6 rib bolts onto it .
