Water Pump Leaking From Front
Just want to know if there is a seal that goes on the front cover of the pump. No coolant leaking from the weep hole so the pump is actually still good. The pump has a very small leak I would hate to have to replace it because of it.
The weep hole is where they usually leak from when the internal seal fails. Maybe you have a leaky water pump gasket.
The pump will always pump coolant, regardless of what happens to the seals or how much they leak.
If the weep hole is leaking, it usually will not stop. Gotta replace it. If its a gasket, you better replace them before it blows bad and sprays coolant out fast, not just a drip.
I had to replace mine 2 times in same day. First unit I got had a wobble in the pulley. Found out after replacing and test driving the car. Lesson learned! Spin the pulley and make sure your replacement pump is good.
I'm sure people can tell that the car in my pic is not a 98 or above due to the lights. I have an ugly hood? Thanks dude I hope that makes you feel better. So where are the pics of your cars?
Yeah I really figured people would see the pic or check my profile. I was pissed off when I started the thread because I went to 2 auto parts stores and both people at parts didn't know what a 97 trans am was so of course they had no idea what I was talking about with the water pump. I ended up buying a new pump that I have yet to put in because of the cold weather.
I had this issue when I first got my trans am the dealer put stop leak in it to keep it from dripping till after I had gotten it home I just went to Autozone and replaced the whole thing the gaskets were metal and rubber the replacements were cork I think....
