Garage clean up in California. Performance and stock.
Category: Accessories
Price: $20
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): CA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
$60 Center bolt valve covers and coil brackets.
$150. BBK TB ONLY w gasket+sensors+spacer
$25 Percy's split-lock header bolts in stainless. (discontinued)
http://www.speedwaymotors.com/Garage...-12,42283.html
$10 each obo (2x) 1998 camaro owners manuals with vinyl cases.
$15 "Budge" brand car cover size #3 that fits ls1 camaro
$45 98 camaro ls1/t56 radiator with sensor
$65 Rear ls1 disc setup no backing plates.
$35 *Comp Cams #249-7639-16 Magnum Pushrod Set. You can hear the sound change as they roll, so I would assume they are very slightly bent.
5/16'' Diameter
7.450'' Length
End Type: F-F
$45 *Thunder racing
5/16'' Diameter
7.350" Length
.080 wall thickness
$95* Trend Racing (thick)
7/16" Diameter
7.425" Length
.120 wall thickness
$25 Lingenfelter Cone/oval filter 4" opening
SIMILAR but mine is larger:
https://encrypted-tbn0.google.com/im...mC7uCLOSDbkjBY
$20 AEM ~6x5x9 4" opening
SIMILAR: http://www.aemintakes.com/store/prod...Prod=21-2059DK
$90 Used MOTIVE 4:30 gears (12bolt). Great condition.
$10 each pipe (2x) 2.5" steel u-bends and (1) 2.5" J-bend.
Used vette parts:
**PSG SIDE ONLY**NOTHING ELSE BESIDES WHATS LISTED**
front control arms $70 each upper or lower
spindle/knuckle (works on front or rear) $100 (psg side)
Steering rack $75
Cradle(the 2 locating nubs have been ground off) $25 obo
Shocks $35 for both
Front leaf spring $50 SOLD
Sway bar $20
$215 oboAVIC-N1 Pioneer Touch screen DVD/CD/MP3/GPS/Radio In working order. The screen alignment is a little off, but can be re-calibrated on your own. Plays music and movies just fine. Navigation also works fine.Description of alignment problem:
The screen and what it displays are perfectly center. Think of the keyboard input screen (in QWERTY format of course). When you try to press "A", it will select "D". All touch inputs are skewed a little to the right.*
Fix:
1. Take disc out.
2. Press and hold eject and push the reset button. (don't release the eject button 'till screen closes and opens again)
3. Screen will ask you to push reset.(don't)
4. With right ****... up,up,down,down,push
5. Perform steeps 1,2,3,and 4 only:
The first outlines the screen
The second has you push hash marks
The third verifies
The fourth Saves
6. Use "Band" button for "back"
I got this on a trade from someone I trust and never got to install it.
I dont check PM's often 408 38 6 7 nine 9zero Call or text
