Help with figuring out correct spacer/adapter width
I'm having my stock WS6 wheels widened in the rear and need to throw a hubcentric adapter on there to push the tires out a bit. I'm trying to figure out how wide of an adapter I need to get my WS6 wheels to stick out exactly how my drag wheels did which were flush with the fender. I have no idea how to do offset calculations so here are both wheel specs:
Stock WS6 wheel = 17x9 with 50mm or 7" backspace
Drag Wheels = 15x8 with 4.5" backspace
Thanks!
Thanks!
I'm thinking 10.5" wide so I may not have to BFH it but I'm still undecided between that and 11". Basically I'm stuck between running a 1" or 1.25" adapter for look purposes. By the way your pics have been very helpful, I've been doing a lot of searching through threads.
Edit:
If you want your WS6 wheels to fit the same in terms of flushness, run a 1.5" spacer. The width that your wheel is widened will not change this.
If this is the look you like, I would go 17x11, since a wheel with that much backspacing should be nowhere near your inner fender.
A WS6 wheel, widened to 11" (with a 1.5" spacer) will effectively become a 17x11 ET 38, 7.5" BS.
All went to 17x11 and all used 1"
https://ls1tech.com/forums/wheels-ti...s6-wheels.html
https://ls1tech.com/forums/wheels-ti...s-updated.html
http://www.ws6.com/wheels.htm (on an LT1)
Assuming the 2" are added to the inside of the mounting surface, it will add 2" of backspacing. You said the wheels are currently 7"BS. Stock 4th gens can handle 8" BS but not 9". So a 1" adapter/spacer will make it so there is room inside. It will also push the wheel out 1" toward the fenderlip from stock.
All this figuring and all it takes is a measuring tape. While the wheel and tire is on the car, measure the distance from the front face of the tire to where you would like them to be in relation to your fender lip and then buy an adapter the size that you measured.
Here's a couple shots to show where mine sits with a 1" spacer. I was trying to best picture how they sit under the fender, and Im really happy with where they are. Some of the pics I posted before made them look like they stick out, but they are tucked nicely.
And still one of my favorite shots:
