Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
RB racing scavenge pump
Old 12-12-2012, 11:31 PM
jrocstar's Avatar
Default RB racing scavenge pump
Category: Racing Parts
Price: $175
Location (State): MI
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
I am eliminating my scavenge system for my turbo. I am changing my charge piping so it can be gravity fed and changing to a ball bearing comp turbo requiring little to no oil to flow. Basically I do not need this anymore. Its perfect for rear mount setups that need oil scavenging. It is the small version 03-1040. I have one of the straight -10AN fittings in case you need to adapt it. The other fitting is on my power steering pump currently. It has the standard fittings on it that come with the pump. Pump has about 200 street miles on it. Worked great just want to remove any components not completely necessary for my front mount setup. Text me with questions 616-835-1464
Old 12-13-2012, 01:16 PM
jrocstar's Avatar
bump for the afternoon
Old 12-13-2012, 01:40 PM
MIGHTYMOUSE's Avatar
can small version support two t4 turbo's?
Old 12-13-2012, 02:46 PM
jrocstar's Avatar
depending on oil volume yes. It can handle 2 gallons per minute so if you think you can fill 2 gallon jugs per minute of running or more then I would not advise this pump. If your running a -4 line unrestricted I would say no it cannot handle that. If your restricting the line at all or running -3 you should be fine. I ran this on a -4 hose unrestricted on my front mount and after about 20 minutes of driving it started not being able to not keep up to the 80 psi oil pressure on my ball bearing turbo. Restricted it slightly and had no problems at all. This pump will literally pull a vacuum on your drain line that will suck your thumb HARD. I was very impressed.
Old 12-14-2012, 03:27 PM
jrocstar's Avatar
back up top
Old 12-16-2012, 04:01 PM
jrocstar's Avatar
Someone has GOT to be doing a rear mount setup and needs a scavenge pump!
Old 12-17-2012, 08:42 PM
jrocstar's Avatar
bump for best offer
Old 12-18-2012, 12:34 PM
sprayedenali's Avatar
very nice pump!! GLWS
Old 12-19-2012, 05:55 PM
jrocstar's Avatar
Thanks! I love the "Eat ****" page they have. Its what convinced me to buy from them.
Old 12-19-2012, 08:35 PM
jrocstar's Avatar
gone!
Quick Reply: RB racing scavenge pump
