Radiator with -16 fittings welded on
I would like to have my radiator built with these vs the standard inlet/outlet barbs like this one. This will give me more freedom to route the hose to the water pump. My question is, how do you connect it at the water pump? Do you have to weld the same fittings on the water pump? Do they make a thermostat cover with that type of fitting or is the -16 the same hose size and you just use regular clamps on the water pump side?
Location: Land of the Mormon's although I'm not one of them
You have to AN fitting the whole thing; if you do it on one end, it has to be at the other as well. Any radiator shop can weld the fittings to the radiator (or should be able to); and any competent welding/fab shop should be able to modify and TIG weld the waterpump.
http://www.summitracing.com/parts/ear-at309120erl I have some -20 weld on bungs didn't go that route because of the cost of the hose ends and hose http://www.summitracing.com/parts/ear-350320erl couldn't justify $500+ in radiator hoses!!
-16 is sufficient. You can have bungs welded on your current radiator. I ordered mine with them from CBR.
Custom Built Motors in Rancho Cucamonga CA sells a press-in -16 AN bung for the upper fitting, and a -16 thermostat housing.
16an is perfect with two pusher fans my temp are at a steady 185 ...cbm on ebay sell the thermostat housing
http://www.ebay.com/itm/CBM-10615-GM...item43b0e2d397
Does anyone know if they make a 90 fitting in size -20? I need my inlet and lout let fittings to come out of the side of my radiator and would make it easier if I could weld a 90 there.
Only see -16 here
http://www.racepartsolutions.com/products.asp?cat=98
Other option could be to use a 180 degree fitting if they make that in -20
Only see -16 here
