how much boost are you pushing your stock bottom end iron block?
how much boost are you throwing at your cast iron motors with stock bottom ends?
just wondering if there are any new guys.. ive seen these things handle like 600 and 800 rwhp and like 15 lbs of boost all day...
just wondering if we got any personal stories?
I added a boost controller (finally) to my 5.3/pt88 combo and through a 4l80e and 14 bolt, in my 01 GMC scsb, 19lbs made 718hp to the tire. But doesn't mean anything until it works at the track.
Enough said. I will probably sc mine with a f1 in a year or so. Ill probably push 10lbs just to be safe.
The heads i will have will be built enough to handle the pressure
(Brian tooley or PaC springs, hardened pushrods, ls7 lifter, stock gm rollers, katech bolts, ls9 gaskets, rofessionally hand ported, might do something with those valves after i turn up the boost
