transmission experts step inside
Had a question, How hard would it be to change the range select shaft on a 2004 4L60e from a long one like this
To a short one like found on 700r4 and older 4L60e w/o the mounted safety neutral switch
is this something that's easy to get to by dropping the pan? I didn't know how involved this would be?
And anyone have any idea where I can get a short range select shaft online to make this swap?
Thanks in advance
Thanks in advance
Yes, you can do this by simply dropping the pan. You need to remove the U shaped spring clip near the rooster comb and then back off the nut to remove the shaft from the case.
ok, best I can tell it's called a "shift shaft"....does anyone have a part number??
I found this guy on ebay selling used ones...is this a good price?? or is there a source with a better price?
http://www.ebay.com/itm/260769134501...=p5197.c0.m619
