LT1 Loud squealing when you step on the gas
Old 12-20-2012, 11:10 PM
iTh3 Riddler's Avatar
Default LT1 Loud squealing when you step on the gas
Alright so I drove my car to dinner on Tuesday night and she ran like a champ. Went to pick it up from my girlfriends Weds and she started fine but when you step on the gas she squeals like a pig and has some serious power loss. I have no idea where to start. Luckily I have a second vehicle so I am not in a hurry. Any suggestions on what it could be or where to start. Its a 1995 Firebird Trans am with the LT1 motor 6 speed transmission.
Old 12-20-2012, 11:17 PM
cprmn14's Avatar
serp belt?.. or bad pully maybe. Need more details
Old 12-20-2012, 11:22 PM
Well I ended up driving it home about 3 miles but she kept wanting to stall cause she was loosing power and I would floor it in first and second just to keep her moving. I can't hardly tell if the belt is slipping or what.
Old 12-20-2012, 11:23 PM
duh
duh's Avatar
^+1 check and make sure all the pullies are spinning. If one's frozen up it'll chew through the belt in a heart beat
double check that the belt is still in one piece. If it's still there start looking at the charging system. Sounds like the bearings in the ALT could have bit the dust as well
Old 12-20-2012, 11:26 PM
cprmn14's Avatar
Sounds like:
A) you broke your belt
B) your alternator pulley locked up on you
or both. lol
Old 12-20-2012, 11:30 PM
Sounds like:
or both. lol
lol belt is definitely still there. I'll check tomorrow to make sure everything is actually spinning tho
Old 12-22-2012, 01:44 AM
Well it seems the squealing is coming from the alternator but the alternator is still good cause car kept running when we disconnected the battery with all accessories running. However I now think my cat is clogged so I may just remove my exhaust and see what happens ha
Old 12-22-2012, 05:11 AM
popo8's Avatar
Bearings in the alt can still be going out and making noise while it still works... But... When it locks up...expect to lose ur belt....
Now...
Y do u think the cat is out...
Old 12-22-2012, 08:20 AM
shbox's Avatar
Originally Posted by iTh3 Riddler
Well it seems the squealing is coming from the alternator but the alternator is still good cause car kept running when we disconnected the battery with all accessories running. ...
You should never do that on a modern car. It can ruin the alternator. Of course, if it is squealing, you need to address the issue anyway.
Old 12-22-2012, 09:04 AM
trilkb's Avatar
so its not the back tires? hmmm....odd.
Old 12-22-2012, 11:46 PM
popo8's Avatar
Well, what was it?
Old 12-23-2012, 08:02 AM
wrd1972's Avatar
Yeah and the following really happened to me. The big front bearing in the alt walks backward out of its socket in the aluminum housing and the plastic fan blade starts grinding against the housing. Sounds like nails on a chalkboard. I lightly JB welded the socket and machined it out to simply better snug the bearing in place. Only reason I went to that much trouble is because the alt housings are painted.
Old 12-23-2012, 10:39 AM
joelster's Avatar
Take the serpentine belt off and start the car. The water pump is gear driven so it won't run hot. If the squeak is still there you have an internal engine problem.
Old 12-23-2012, 06:15 PM
cprmn14's Avatar
You can take the alt to a rebuild shop and he can replace the pully for a fraction of buying a new one. Start there I'd say
Old 12-24-2012, 10:03 AM
djjab57's Avatar
I thought mine was the alternator but ended up being the A/C . Froze up and had a great smoke out
Old 12-24-2012, 10:14 AM
quik95lt1's Avatar
been there done that my a/c compressor locked up solid when i first put my 385 together and was on the street with it.....makes a hell of a noise and mess lol
Manic Mechanic's Avatar
His cat is clogged. The squealing noise is the high exhaust pressure escaping from the weakest point of the system ahead of the cat, probably the manifold gasket right behind the alternator. There's not a belt driven accessory known to man that will over power a v8 at heavy throttle. But a clogged cat will do this with ease.
OP since you left it at your GF's house overnight unattended make sure somebody didn't shove something up your tail pipes to clog it up before you cut off the cat.
Vernon
Old 12-24-2012, 11:33 PM
Tinbender59's Avatar
what he said ^^^^^^
Old 12-25-2012, 12:08 AM
Vernon
Tailpipes appear to be clear. I may chop out the cat tomorrow because I have been busy the last few days with family for christmas. I have a feeling the cat is the problem.
Old 12-25-2012, 09:52 AM
Village Troll
SS RRR's Avatar
So you might have a built in whistletip. Woooowwwwwwwwwwooooo!
I dunno... I'd think there would be a distinct difference between a whistle and a squeak. Any way you can get some audio of this? Anyone mad at you?
Quick Reply: LT1 Loud squealing when you step on the gas
