s475 on untouch ls1, what to expect with 9psi
Old 12-21-2012, 07:52 AM
mrstepheneades's Avatar
Default s475 on untouch ls1, what to expect with 9psi
so just ordered my s475 turbo with 96mm turbine wheel and 1.32 a/r from forced inductions........ thats what they recommended. The car still has stock cam and intake. Like i said long block is untouched. It will be front mounted using manifolds.
60-75 pound injectors
possibly meth injection to be safe..
What should i expected rwhp on 9psi????
Not looking to set any certain number just like to know what to expect.
I have a 6.0 on engine stand for forging future for a backup but wanna run a safe, fun tune on the stock ls till it lets go. Since its already in there lol....
All input is appreciated...
Thanks
Old 12-21-2012, 08:48 AM
turbocamaro125's Avatar
what trans? t56 prolly close to 600. I had a s480 at 9-10psi with a blower cam and 102/102 combo and it shoulda been over 600whp but never dynod it.
Old 12-21-2012, 09:09 AM
Its a t56................ and cam is staying stock on this engine. to cheap to put another one in it lol. Ill spend the good money on the future 6.0
Old 12-21-2012, 10:52 AM
lurker1978's Avatar
My guess would be current rwhp x ~1.6 for 9psi, should put you in the 450-500 range.
Old 12-21-2012, 11:34 AM
67Firebird455's Avatar
Honestly, at 9psi with an S475, I really don't see you being any less than 500rwhp on a t56. There are many people in that range with smaller turbine units pushing closer to 550rwhp at close to 10psi on ls1's. It's all in the tune though, remember that. =)
Old 12-21-2012, 12:19 PM
atomic 6's Avatar
Stock valve springs??
Old 12-21-2012, 12:30 PM
Blackpanther99's Avatar
I doubt youll see over 500
Old 12-21-2012, 12:43 PM
Yes stock everything. Anything over 500 will be satisfying till i get the 6.0 built.
Old 12-21-2012, 01:33 PM
jridenour31's Avatar
At least put some decent springs in it.
Old 12-21-2012, 01:45 PM
im in the dark why i would need springs if i dont plan to turn rpm higher than stock limiter setting. Not doing rod bolts so plan to keep rpm down.....
Old 12-21-2012, 01:54 PM
TrickrTreat's Avatar
Its not just rpm , but it has to do with how much harder the cam lobe will be throwing the valve open ( along with forced air pressure pushing on the valve) and having enough spring pressure to snap the valve shut.
trust me if you dont do springs , youll be "that guy" making a , "help me figure out why my car wont make any power past 5400 rpm" thread . Dont be that guy.
With that being said, im going to say , 475-480 rwhp
Old 12-21-2012, 02:12 PM
Ok thanks. Springs not much. Probably will get some now that i see the point.
Old 12-21-2012, 02:36 PM
Ryans99ls1's Avatar
you need springs and pushrods at the very least. if you put over 10* timing in it you should see over 500, but again its all in the tune.
Old 12-21-2012, 02:45 PM
well if im gonna do pushrods and springs i might as well get the cam to lol. That would pick my power up even more..... But i want the weekender to last a while so not wanting to push my luck. And again i could transferr cam over to 6.0 later to so its spend money now or later basically. Any tips for turbo cam??
Old 12-21-2012, 03:07 PM
JRENIGAR's Avatar
check your pm's...
Old 12-21-2012, 03:35 PM
[QUOTE=JRENIGAR;16996552]check your pm's...[/QUOT
pm chked
Old 12-21-2012, 04:59 PM
I wouldn't throw a cam in it just because you're already putting springs and pushrods in it, you only have to pull the valve covers for those. I would, however, put a cam in it because it will help spool and power. Also, it's not going to be any less reliable if you keep the rpm's in check.
Old 12-21-2012, 05:02 PM
Boost against the back of the intake valve will be fighting against the valve springs causing float.
Old 12-21-2012, 05:33 PM
Thanks for the input guys
Old 12-21-2012, 07:27 PM
Jeez, I missed the springs part, yes... definitely, while you're doing it, toss a good cam in there with pushrods and springs and go for it. You'll be happy with it.
Quick Reply: s475 on untouch ls1, what to expect with 9psi
