Tring to figure out what my po was thinking?
After almost a year of owning my car I looked under the rear end thinking I might need rear shocks. I never imagined there were no rear shocks at all. Wtf was he thinking. I think I may grab a front & rear set of the Stagg. I wish I had the spare cash for the Koni's or Billstein's but that is not in the pic. At the same time I will do the front lca's and I may spring for a Strano front sway bar. My fronts are orange is that factory or were they replaced. Sorry, dont know how to adjust the pic & going to por 15 the bottom in the spring.
http://i32.photobucket.com/albums/d4...psd2352a56.jpg
the shock is there, its in front of the spring, we dont have coilovers in the rear.
Orange shocks are the factory decrappons. Save up for at least bilstiens, they are under $400, don't buy anything before shocks, thats where the money should be going as they will make the biggest difference out of anything.
Just make sure you search, search and search again before buying anything - you may get something that you find out later you wasted money on.
Also when buying the swaybars buy the pair. I bought the front strano bar first, then the rear later. With strano front/stock rear the rear felt like it was lagging behind in comparison and not well balanced.
And what makes you think you need new front LCAs?
That's MISTER MODERATOR
Carguy, just a thought here, no insult or injury intended....
If you didn't realize there are rear shocks on your car, should you be doing this kind of work yourself?
I'm also a little concerned about the rust on smaller parts like fuel & brake lines.
Just trying to play it safe here....
No offence taken lol, I am smart enough to know I am not handy. Butchers are more dangerous. I still don't know how I didn't see them. Im going to look again. The po had the car near water or outside. Now its garaged and I will have the bottom por 15 ed in the spring.
I meant to write lca bushings only that my mechanic who is good noticed. I only hear good things about bilsteins. I guess by the price they are a better piece then the stagg, the difference can't only be the name. I will probably do the same as u with the sway bars. What does the rear lagging feel like?
Ha, its happens.
Yes, Bilstiens are a very good quality shock for the money.
Replacing lower control arm bushings is no trivial task and you'll need an alignment afterwards.
If you can afford it, I would suggest you buy complete GM lower control arms. They'll come complete with ball joint and bushings. These 1LE arms are what came on your car and have a bit harder rubber in the bushings for better handling.
Left: 52367658, right: 5236765
Absolutely they will be done by a shop. I would not ever consider doing that. Lol. I don't know how much for the complete units, they would be awesome but I bet I can't afford them now. I will buy bushings & the big front sway bar from Strano in the Spring. First I need to install shocks, I went for a ride today which was my first cold day and they were banging. Lol.
Also, this is for everyone. After advice from you guys I re jacked up the car, and looked in front of the wheel & vola there it was. Orange and tucked in pretty good. I was thinking it should have been in a similar position as my 69Camaro but appearently not. Lol.
