Anyone using shorter rear shocks?
My car is away for the winter and I have been thinking about the rear suspension. I want to lower the rear another 1/2" but I'm really close to bottoming my shocks where I'm at. Also the watts link is hitting on my gas tank now, but I plan on getting a new tank and welding in a relief so it doesn't hit anymore.
But if I were to get different shocks, what would my options be?
I don't want to spend a bunch of money on shocks, but I could probably swing ~$150 each. I thought about dropping the lower shock mount, but I'd rather get the right parts and not cut or weld on on my MWC rear.
I want to get a shock that's more towards autox vs the drag shocks. I may run the Edelbrock shocks one more summer and see what happens. I have hit the bump stops a lot, but I also upped the spring rate from 175# to 200# at the end of summer and I'm taking a lot of weight out of the car this winter. Maybe if I crank down the jack bolts and fix the gas tank I can get away with them for another summer.
I'll check out the Ridetech HQ shocks though 99Bluz28, what are you using on your car now?
No, I'm not using the Ridetech HQ shocks, but they look to be a quality shock an run about $175 ea.. I'm currently still using the Koni SA shocks with the GC bumpstops on the shock shafts which is still working great for me. I can't remember right off but are the IAS shocks longer that the Bilsteins or Konis rear shocks? If I remember correctly the axle tubes should contact the body before the shocks bottom out.
Bilstein has the rear #24-010214 shocks which have about a 3/4" shorter extended length (then the HD bilsteins) for use with lowering springs. You can get them for about $80 ea..
I'll look into the Bilsteins, but I think I may need something even shorter. I don't know if my car is just weird, or whats going on. I may pull the shocks and shave down the isolator to give it another 3/8" of travel but other than that I don't know what else to do other than getting a shock extender or shorter shocks.
Like I said before I'm removing close to 400#s out of my car this winter so thats going to change a lot of things, so I may just wait and see how it feels next spring and go from there.
