Can anyone tell me what these are! help! Pics inside
Hey everyone I bought these springs a month or so ago for a upcoming cam swap on my ss.. ill be going with the TSP 228R
I bought these springs used and was told they were pac .650 and nothing else
they came off a GMPP 243 heads that was on a bored out ls6 engine 416 stroker.
They might not be a PAC spring.
I dont give two ***** what they are as long as I can use them.
they are basically a dual spring with a damper
The reason I need to know is because I was sold 16 springs, 16 valve seats, but only 14 retainers. So im trying to track down two more.
Im hoping someone has seen or used these before and can point me in the right direction.
how do I know what the installed height should be?
These only have about 3k miles on them..
can anyone point me in the right direction?
do these look to stout for my application?
Im going with the TSP 228R.
I dont want to buy new springs if I dont have to
You'll need to find a shop that can check them first, so you'll know what you have. If they check out OK, you might shop them on Racingjunk or Yellowbullet. Martin would know better, but I don't think the LS heads can be opened up for a larger OD spring w/o getting into the water jackets.
