What's 1 7/8 headers worth over 1 3/4 on a procharged car making 15psi?
Old 12-30-2012, 07:59 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Default What's 1 7/8 headers worth over 1 3/4 on a procharged car making 15psi?
I'm currently making 15psi of boost at 6800 and my exhaust consists of original QTP 1 3/4 headers (standard merge collector) with a Kooks ORY into a Magnaflow catback.
Is it worth it to go with a set of 1 7/8" headers (ARH) vs. what I have?
Old 12-30-2012, 08:14 AM
mikh338's Avatar
not sure but i have a brand new set of TSP 1 7\8 never bolted on or used for sale if you are interested
Old 12-30-2012, 08:43 AM
UNDER PRESSURE MOD
PM me a price shipped to 18902.
Old 12-30-2012, 09:00 AM
No Juice's Avatar
I'm interested as well. What about a pair of cut outs in the y-pipe?
Old 12-30-2012, 10:19 AM
TheLS1Lover's Avatar
I think you would pick up more going with a Flowmaster Merge or True Duals.
Old 12-30-2012, 11:19 AM
ajrothm's Avatar
I honestly don't think you will see much...definitely NOT worth the money unless you got a steal on the headers.. Hell going to a 2" primary probably isnt worth much more..
I went from LG Super Pro 1 3/4" on my old stock motor/D1sc setup to 2" ARH on my new build, so it was not an apples to apples test to see header gains alone but...My gut instinct is I really didnt gain much at all from the header swap... Maybe 20hp or so in the 900hp area... Definitely not worth the $1600 it cost me for new headers/x pipe...
I will say the 2" ARH headers fit damn good though.
A buddy of mine just dynoed 816rwhp with a D1SC at 15 psi on a 402"/ported 243s with 1 3/4" headers from Breathless Performance in a C6/stick car... I thought it was DAMN good for a D1...
Old 12-30-2012, 11:32 AM
UNDER PRESSURE MOD
Thank you for this post. It's probably not worth it then. Hell, I'm still only commanding 14-15 degrees of timing, I bet I'd see more of a gain adding a degree or two than I would see from swapping headers, and all that requires is a few keystrokes. Before anyone screams about safety, I'm spraying meth/water, on a forged motor and don't get any knock, so going from 14 degrees to 16 or 17 isn't unsafe.
Old 12-30-2012, 11:37 AM
Captain Double Post
BOBS99SS's Avatar
I would think 1 7/8ths,and a nice true dual exhaust would net you some gains,my car pulled alot harder with duals vs the magnaflow,it depends though,if your trying to get every lil bit out of it, its worth it,if it was me i would just add a cutout and call it a day,and up the boost a bit lol,but im cheap
Old 12-30-2012, 11:49 AM
lemons12's Avatar
Kp says otherwise with 1 3/4 vs 1 7/8. I would go for it.
Old 12-30-2012, 12:22 PM
js2fst's Avatar
I thought kp said otherwise what did he say
Old 12-30-2012, 12:29 PM
lemons12's Avatar
He had posted the gains somewhere in one of his threads.. We swapped several pms back and forth, he recommended 1 7/8s with a very free flowing exhaust.
Old 12-30-2012, 12:35 PM
UNDER PRESSURE MOD
So some say it's worth it, other's say no. LOL, sounds clear as mud.
js2fst's Avatar
My dynatechs are trash so I am thinking about 1 7/8 with true duals
Old 12-30-2012, 12:47 PM
lemons12's Avatar
Not to argue... But the procharger gurus say 1 7/8... Others are mixed 1 3/4 vs 1 7/8... Id take my chances with the 1 7/8.
Old 12-30-2012, 12:49 PM
jjcamaro02's Avatar
I am running 93 octane with meth AFR is around 10.9 -11.2 with 18 degrees of timing. You will feel a big improvement going from 14 to 17 degrees. Just keep an eye on your plugs. Save your money on the headers for now.
Old 12-30-2012, 01:31 PM
allout06's Avatar
My tuner ran 18* timing in my D1 setup i had, 11.5ish AFR, no meth on 93 and i beat on it for a year.. i think a few more degrees of timing is where your gonna see an improvement.
Old 12-30-2012, 02:40 PM
Packy's Avatar
A year ago I switched my old Mac mid-lengths with an ORY out with some TSP 1 7/8 inch LT's with an ORY and gained 29 hp and 18 lb ft of torque. Nothing else was changed when I did this. Not quite apples to apples but I thought it was worth it.
Old 12-30-2012, 02:52 PM
Blackpanther99's Avatar
It will be worth it, I cant say you will see a HUGE difference but its been proven that 1 7/8s are better on the long run if you can I would do it.
Old 12-30-2012, 04:04 PM
UNDER PRESSURE MOD
Louis posted a few days ago the power of timing and showed that 2 degrees of timing was worth like 30 rwhp and torque. I think I'm going to get my sled on a dyno and see what I can do with the tune and go from there.
Old 12-30-2012, 04:10 PM
Packy's Avatar
Yeah that is still subjective to your particular set-up. I mainly changed them out because I pulled the tires once and the Mac's connected with the K-member causing a dent. Plus they were old and sad looking. I was happy with the results. I also changed nothing with the tune on mine since doing the swap.
Quick Reply: What's 1 7/8 headers worth over 1 3/4 on a procharged car making 15psi?
