19x10 25mm off-set(formerly 38)
Old 01-02-2013, 01:04 AM
RikkiTorment's Avatar
Default 19x10 25mm off-set(formerly 38)
Should I be okay running my 275/30/19's on a 19x10 wheel with a +38mm off-set as my fronts and rears???
Old 01-02-2013, 01:36 AM
99Bluz28's Avatar
That shouldn't be a problem with a 275/30/19, but why not a 295/30/19 ?
You might need to roll the rear fender lips if you go with the 295/30/19s.
Old 01-02-2013, 01:42 AM
The rims that I have on my car now 19x9.5 with an unknown off-set and still have about another year or so left on them. Unfortunately those rims that are on my car now are literally rotting away, they are cracking and rusting out. As a poor college kid, this is my easiest/cheapest solution haha
Old 01-02-2013, 02:11 AM
chaman's Avatar
That is my setup and have no problems with it.
Old 01-02-2013, 02:26 AM
No spacers or anything? Trying to order these things tonight so I can get free shipping (save $100+) lol
Old 01-02-2013, 02:28 AM
chaman's Avatar
No spacers on mine. Good luck!
Old 01-02-2013, 02:37 AM
Awesome! Good to hear, post up a pic or two if you can. Would like to see as many 19x10's as I can haha
Old 01-02-2013, 02:42 AM
chaman's Avatar
Mine is 9.5 not 10....sorry about the confusion. Either way I think it doesn't matter....
Old 01-02-2013, 07:37 AM
And you think the 19x10 should clear okay? Because I can do 19x9.5 I just wanted the aggressiveness of the 19x10 lol
Old 01-02-2013, 05:40 PM
chaman's Avatar
My guess is you would be okay, but you may want to contact a member here named "Guitar", I think he is running 19x10 or 11. He may have the info you need.
Old 01-02-2013, 08:26 PM
gobaltss's Avatar
Sounds like it will be tight, hope it works!
Old 01-03-2013, 06:45 PM
CP-Z28's Avatar
You could try using this calculator
http://www.willtheyfit.com/
it should give you a bit of an idea.
Old 01-03-2013, 07:14 PM
I ended up ordering 19x9.5 40mm off-set for the fronts and the 19x10 and 38mm off-set for the rears.
Old 01-04-2013, 01:51 AM
Mr.z/28's Avatar
do you mind telling us what wheel??
Old 01-04-2013, 11:02 AM
It was a VMR VB3 but every outlet is sold out of the matte black or hyper black with just gun metal and silver in stock... So I canned my order.
Old 01-04-2013, 03:42 PM
I have the option of 19x10 with an et of +25mm for the rear set... Will that work?
Old 01-04-2013, 05:12 PM
codysgto's Avatar
Your best fitment would be 19X9.5 45mm. The lower the # ie 25mm, the more it is going to stick out past the fender.
Old 01-04-2013, 05:36 PM
cemlsx's Avatar
I run around 35 offset in the back with 19x10.5 , they only scrape if there are passengers in the back ( fat ones ) and I go over bumps or something.. never scrapes otherwise..
btw I`m running 275`s..
Old 01-04-2013, 05:51 PM
It will be 19x10 at +25 with a 275 on it.
Old 01-04-2013, 05:56 PM
Currently running hp design hpr5 at 19x9.5 +38et with 275s on them. Looking to use the same tires
Quick Reply: 19x10 25mm off-set(formerly 38)
