twin 6165 vs. twin 6162
Hello i want to know if anyone has any personal experience or input on those turbine sizes as twins. On3 utilizes the 65mm turbine and cx racing uses the 62mm turbine and both turbos have a 61mm compressor. I know the 65mm turbines will spool fine but my real question is if the 62mm turbine on the cx racing turbo will become a restriction. The cx turbos are only $500 and the on3's are $650 and they are both the same Chinese stuff anyway. I'm probably going to push this setup for 8-900hp max. This is going in a s10 with lq4 and th400.
