turbo 4.8/5.3 setups, what RPM stall are you running?
Old 01-05-2013, 07:12 PM
a4ls2goat's Avatar
Default turbo 4.8/5.3 setups, what RPM stall are you running?
what RPM stall are you guys running on your 4.8/5.3 setups?
ill be building my 4L65 soon, and will be getting a triple disc converter, currently running a single disc 3500 stall, which sucks on the foot brake
Old 01-05-2013, 07:15 PM
67Firebird455's Avatar
I've got a 3800 in my 67, have yet to run it, but it's a 400 also, so I wouldn't be able to compare it to your 65E.
Old 01-05-2013, 10:20 PM
CameronVic's Avatar
3200ish. I have megasquirt and launch control so I have the ability to pull timing and set a 2 step with a button so I can build 10-12ish psi at 2600-2800 rpms. But yea, before I figured that out, the thing left like a mutt.
Old 01-05-2013, 10:26 PM
o2camaross's Avatar
about a 3000 or a touch more on a TH400
Old 01-06-2013, 01:31 PM
Wicked69's Avatar
3400 with a TH400, 2 step, and a TB.
Old 01-06-2013, 05:34 PM
silver_82's Avatar
I have my 2-step launch set to 4700 and it flashes to 5800.
I need the rpm for it to leave hard
Old 01-06-2013, 07:06 PM
LS1NOVA's Avatar
Yank PY3600, wish it was a tad more though.
Old 01-06-2013, 07:42 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
8 inch??
Old 01-06-2013, 07:50 PM
a4ls2goat's Avatar
What rpm does your setup hit full boost?
Old 01-06-2013, 08:24 PM
FAST LS1's Avatar
I have a ~4k rpm triple disk Circle D sitting beside me that's going in my turbo 5.3L build.
Old 01-06-2013, 09:52 PM
My concern with such a high stall is obviously streetability. I'll use a lower stall plus nitrous if I have to vs a high *** stall. lol Would imagine it'd have to be much higher for a tall geared, tall tired heavy machine.
Old 01-20-2013, 09:56 AM
silver_82's Avatar
8 inch??
9.5. Its got a glide with a tall tire and fairly tall gear. It drives around great on the street.
Quick Reply: turbo 4.8/5.3 setups, what RPM stall are you running?
