19x9.5 33mm
Old 01-07-2013, 12:54 PM
RikkiTorment's Avatar
Default 19x9.5 33mm
Is 19x9.5 at 33mm with a 275 tire too drastic to run on the fronts or rears? I also have a 19x9.5 at 40mm, and 45mm option... I just don't want it hanging out too far and looking like an off-road tonka toy. I just need help... All of the sizes for the model I want are sold out at every outlet and the manufacturer has not reached the amount to make a new batch.
Old 01-08-2013, 01:01 AM
Nobody can tell me of the options I listed which will sit the most flush on a 19x9.5 rim??? The options again are 33mm, 40mm and 45mm... :-\
Old 01-08-2013, 01:03 AM
oChristiano's Avatar
Itll poke out. My rpm505 9.5 with 38mm offset was flush on my SS. 40 should be good on your Bird.
Old 01-08-2013, 01:10 AM
Thank you!! I'm pulling my hair out because I didn't expect every single outlet I could find to be sold out of the measurements I wanted, and the manufacturer not even being able to give an ETA. I'm paranoid that it will look awful with it being an aftermarket BMW rim lol
Old 01-08-2013, 01:16 AM
This is my SS with my RPM 505s. Tire is a 295/30/19. As you can see its pretty flush. It was a 38 or 40mm offset. IIRC It was +38mm.
Birds also have a slightly larger wheel well. Also my car is lowered about 2" wheels were also aftermarket BMW rims.
Old 01-08-2013, 01:26 AM
They look pretty damn good. Anything special to make them fit?
Old 01-08-2013, 01:42 AM
Bolted right up. Ran them for 10k or so. Only sold them because I got. Good deal on some Fikse FM5s.
Old 01-08-2013, 02:00 AM
Awesome, thanks! I'll be running the same 275's that I have on my current wheels which are sadly rotting away. They haven't been produced in a number of years for this bolt pattern so I am literally guessing the off-set... Which I believe is 38mm all around lol
Old 01-22-2013, 12:20 AM
corey98bird's Avatar
oChristiano I have a question for you. My Trans am is lowered 1.75 inches. Think 19inch rpm 505s will fit fine with 295-30-19? Buying them soon do reply ASAP please!
Old 01-22-2013, 02:24 AM
Just saw this, same set up I ran. Already posted in your other thread. Your Bird actually has bigger fenders you might not have to roll your fenders as much.
Quick Reply: 19x9.5 33mm
