97 SS air intake upgrade question
Old 01-10-2013, 02:38 PM
Hulkaholic's Avatar
Default 97 SS air intake upgrade question
So is there a better option for a 97 Camaro SS for Air induction as opposed to the stock SS ram air setup? I see people saying Lid+CAI, I'd like to hear from SS owners who have done a swap of the stock induction for something else. thank you.
Old 01-11-2013, 09:06 AM
jesup16's Avatar
I went from stock system to the SLP CAI. Most will tell you that the LS1 Lid setup is the way to go, as far as actual HP #'s go. I agree, but I really didn't want to hack up my hood, radiator support, or remove the AC.
Old 01-11-2013, 10:10 AM
Steve Stifler's Avatar
I recently got a 96 SS and have been wondering the same thing. I also like the ls1 lid set up but DO NOT want to cut everything up to make it fit.
Old 01-11-2013, 10:17 AM
01Z0H6's Avatar
I kind of like the way my 97 SS's air induction set up is from the factory. Gets fresh air directly from the hood... I'll be keeping mine stock.
Old 01-11-2013, 10:48 AM
jesup16's Avatar
Most will argue that heat soak and restricted plumbing are the down sides to the stock SS airbox. That is why I went with the SLP CAI.
Call me nuts, but seeing as my car is a true SLP car, I wanted to keep the intake SLP.
Old 01-11-2013, 10:52 AM
RamAir95TA's Avatar
The SS hood scoop is not good. I would go with a typical CAI hands down.
Old 01-11-2013, 11:11 AM
Scoobie's Avatar
I was thinking about doing this as well but not selling the SS airbox.
Old 01-11-2013, 05:30 PM
97Z28SS's Avatar
I would go woith a lid and you don't loose the ac to install it.
Old 01-11-2013, 05:35 PM
Village Troll
SS RRR's Avatar
I swapped it for a LPE CAI about 6 months after buying mine. Mostly because it was always in the way when I was wanting to do something to the engine. Dave Hamburgler himself has admitted the location of the air inlet on the hood is in a dead spot air flow wise and provides very little benefit. I love the looks of the hood, however.
Old 01-12-2013, 01:23 AM
Hulkaholic's Avatar
awesome feedback, thanks guys
Old 01-12-2013, 01:36 AM
Scoobie's Avatar
Has anyone done an LS1 lid swap on a SS model without cutting the hood? If I am going to swap it out once, I am doing it right, once.
Old 01-13-2013, 02:57 AM
JakeSS/Z28's Avatar
K&N cai here (sold from summit under their name save you some cash) with a trickflow elbow, made a huge difference from the ram crap that slp designed the only benefit to the old lt1 style ram air i can see is its almost impossible to suck up water with the hood baffles and height its at
Old 01-14-2013, 11:08 AM
ks my ss's Avatar
I cut the hood baffle out and it helped some. The major problem is that the air is being sucked in the very right side of the intake. Look at a dirty filter, it uses maybe a 1/3 of the filter. I have since switched to a LS1 lid setup. Took alot of work but it fits under the stock hood and looks factory.
Old 01-14-2013, 01:58 PM
Scoobie's Avatar
Old 01-14-2013, 06:04 PM
ks my ss's Avatar
There are pics and info in this section that I posted a few different times.
Quick Reply: 97 SS air intake upgrade question
