Camshaft bearing tool for ls3?
Old 01-14-2013, 11:38 AM
steel_3d's Avatar
Default Camshaft bearing tool for ls3?
Where can I get one? No parts store I called seems to carry one or loan one. Need one by this weekend.
How did you guys get them in and out?
Frickin GM decided to stagger the sizes, so many small block tools don't work, supposedly.
Old 01-14-2013, 11:41 AM
Tainted's Avatar
may take a machine shop to do it if you can find the tools
Old 01-14-2013, 11:43 AM
steel_3d's Avatar
That's not a good option for me for many reasons, so I'd like to do it myself. Thanks.
Old 01-14-2013, 11:44 AM
Tainted's Avatar
well dunno what to tell you then. if you've already tried the parts store and tool rental places you aint got many other options other than order one online and hope it makes it in time.
Old 01-14-2013, 12:19 PM
steel_3d's Avatar
Ended up buying this one http://carshop.carshopinc.com/produc...24334/CSP10900
Was a little worried cause the description doesn't mention LS3, only 1 2 6 7, but the guy on the phone assured me it will work.
Old 01-14-2013, 12:41 PM
Tainted's Avatar
yea they should all be the same since all the cams are interchangeable
Old 01-14-2013, 12:45 PM
steel_3d's Avatar
Was just worried cause the ODs of the LS3 bearings are staggered. But if it goes through the center one, which is the smallest, I'll be ok.
Old 01-15-2013, 04:21 AM
Gunslinger09's Avatar
So did you upgrade the cam or keep the stocker?
Old 01-15-2013, 07:56 AM
Zfan's Avatar
You could just make you own, just a thought.
Old 01-15-2013, 07:02 PM
twinturbo2's Avatar
this is what i did
Old 01-18-2013, 05:20 PM
RezinTexas's Avatar
that is a good deal, let us know how well it works
Old 03-10-2013, 10:49 AM
Eric Fischer's Avatar
can you give us an update on this camshaft installation tool?
Old 03-10-2013, 03:00 PM
Gray86hatch's Avatar
The Car Shop one works on all LS engines.
Tim
Old 03-15-2013, 10:54 PM
steel_3d's Avatar
I didn't end up buying the tool, I found a shop to swap them quickly.
Quick Reply: Camshaft bearing tool for ls3?
