looking for nice thick heads that will fit on a small bore motor.
alright, i am looking to swap out my untouched 862s for some better flowing heads. the car made 840 thru the th400 and 9" with the 862s, im hoping to get more out of it. they will need to fit stock 5.3 bore. and id like the thickest deck possible. its currently on 25.5#s
I've had buddies run the TFS 205's and 215's both on turbo 5.3 engines and the 215's actually made more power. Holdener made 1300 hp with 215's on a stock 5.3 shortblock.
Although since the 220 "LS1" heads have the same CNC chamber as the 215 you could consider those also, like LS1NOVA mentioned.
I know the 215's have a lot of chamber to bore overhang, but they seem to work. They even made more power N/A, almost 510 hp.
You could order them through TEA with PM guides so you can run stock rockers. Or you can order them through me to save sales tax.
You could get the TFS 205's, they use stock 2.00"/1.55" valves, and the stock valves practically flow more than the Ferrea valves they come with. Some 205's with stock hollow stem/sodium filled Z06 valves would be super trick. A buddy of mine ran those exact heads on a 5.3 with a 223/230 cam I did and ran 127 in the 1/8 mile.
I would probably go for the As Cast 220 and at least buy the intake valves, you could have them grind your 1.600" exhaust valves to a 50 degree seat and run them. Otherwise standard 1.600" exhaust valves on that combination will generally make less power.
The 215 chambers have a 3.950" bore to match 5.7 LS1 head gaskets.
I know guys are using 317 heads with 4" bore on these 5.3's with decent results.
I've never liked a lot of chamber to cylinder bore overhang, it just seemed like a bad idea, especially when looking at stuff on a flow bench. But the dyno doesn't lie...
