Help with turbo specs
Old 01-19-2013, 12:09 PM
370cidZ06's Avatar
Default Help with turbo specs
I currently have a 60-1 I know it's too small so I'm not even gonna mount it but I do need help with what turbo I should get .
My setup
370 lq
9.7-10.2;1 comp
317s more than likely
3600 stall 3.42 gear built 60e
C5 z06
I will be making fuel system and cam around turbo power level is whatever it ends up over 650 on relatively low boost
Turbo I'm looking at a little worried about lag and power band
Intake :5 inch
Outlet: 107mm outter diameter, 82.35 inner diameter
Compressor trim: .60 ar (anti- surge)
Compressor Wheel diameter: 74.80 /102.40 (big wheel)
Turbine wheel diameter : 75.35 / 81.70
Exhaust trim: 1.05ar
Turbine flange type: t4 flange ( twin scroll )
Downpipe flange type : 6 bolt type
Cooling type: oil cool only
Horsepower rating: 1000hp+
(wet float bearing)
Old 01-19-2013, 03:24 PM
370cidZ06's Avatar
90 views and no one has any advice ????
Old 01-19-2013, 05:30 PM
SPRAYED 01's Avatar
sounds about right, whos turbo is that?
Old 01-19-2013, 05:36 PM
jridenour31's Avatar
Looks like one of the Godspeed t88 or whatever they call it. Wheel sizes are decent but are probably old technology that doesn't flow what a comparable borg would.
Old 01-19-2013, 05:57 PM
370cidZ06's Avatar
It is indeed a god speed I'm just not tryin to spend a crap ton of money on one was also looking at a gt45y2004
Old 01-19-2013, 08:33 PM
LS1NOVA's Avatar
You have an effin Z06, dont put a $300 turbo on it.
I assume your space limited? Front or rear mount?
Old 01-19-2013, 10:15 PM
370cidZ06's Avatar
Yes I own a z06 and didn't do it by waisting money hints on a budget, front mounted turbo no ac possibly no ps either
Old 01-19-2013, 10:47 PM
LS1NOVA's Avatar
Well if you insist, the one you posted will get the job done without lag. Vettes are a bitch to do a front mount on but without ac and ps it should be doable with a decent sized downpipe. Smaller radiator would make life easier.
Old 01-19-2013, 11:02 PM
LilJohn's Avatar
That turbo will choke on a 370 inch motor.
Pick someone that knows how to cam for the 96mm 1.32 borg warner S475...and re learn how to drive the car.... and itd be fine.
Worrying about lag and stickin a tiny turbo on a bigger inch motor is a mistake.
Old 01-19-2013, 11:10 PM
typhoon1015's Avatar
I was thinking the same thing, I just didnt have time to respond.
Old 01-20-2013, 09:23 AM
LS1NOVA's Avatar
Borg is good, except fitting it in the front of a C5 would be a nightmare. There is a reason there isnt any decent single kits for them and the ones that do have poor plumbing. Your way farther ahead ditching the ac and ps but it wont be easy.
If it was mine Id go with a Precision 8847 since the turbine has a decently sized wheel and the compressor cover is small.
Old 01-20-2013, 09:47 AM
370cidZ06's Avatar
Thank you for a informative response was thinking of a on 76mm but the exhaust side is way to small a 74/64 or something like that I think. I also found a precision t7668 but that's a little small too and yes room is about 8-10ish inches the way I figured making the manifold work etc
Old 01-20-2013, 10:32 AM
LilJohn's Avatar
Bullseye has a T4 based 1.30 a/r stainless Band turbine housing to fit the 96wheel.....
Itd work well in this application.
Old 01-20-2013, 10:56 AM
370cidZ06's Avatar
Any part number or price that you know of?
Old 01-20-2013, 12:42 PM
LS1NOVA's Avatar
Still have a huge compressor cover. How big is that Bullseye turbine? Even T4 I bet its pretty big pysically. It would be awesome to have a nice big unit on there though.
Old 01-20-2013, 01:33 PM
LilJohn's Avatar
The stainless housing is a 400 dollar option. I had Bill build me a pair of these with the cast 80mm borg wheels for a 540 I specd out for a guy.. They were right at 1650-1700 each.
If you want one i could try and pull his string again.
Old 01-20-2013, 01:55 PM
370cidZ06's Avatar
Thanks I just found a 80mm Garrett air research with a 1.39ar t6 frame for relatively cheap. Do you think this would work 10" in length full frame ?
Old 01-20-2013, 02:02 PM
LilJohn's Avatar
Gt4708?
Garrett has dimensional drawings of all thier models on the website... go snag those dimensions and see if itll work.
Old 01-20-2013, 02:34 PM
370cidZ06's Avatar
http://www.turbobygarrett.com/turbob...t/turbocharger
It is a 4708
Old 01-20-2013, 03:51 PM
370cidZ06's Avatar
What's your guys opinion on gt45y2004k ? See it used a lot but not sure for my app
Quick Reply: Help with turbo specs
