blew up the 10 bolt
Old 01-19-2013, 09:09 PM
draggin97s10's Avatar
Default blew up the 10 bolt
Anyway to the point..I got on it couple blocks from the house 1st-3rd gear when i was decelerating it was making some awesome sounds.
Luckily i have a set of spare 410s and a spare posi..so tomorrow i will be tearing into it..
on second note....what would you guys recommend for a rear end...strange, moser ect...?
Old 01-19-2013, 09:11 PM
Rob94hawk's Avatar
Depends on how much $$ you want to spend. I'm leaving my stock 3.42's till I can pony up the dough for a MWC 9".
Old 01-19-2013, 09:13 PM
mwc is a good option
Old 01-20-2013, 08:26 AM
97Z28SS's Avatar
Strange S60 here.
Old 01-20-2013, 09:11 AM
Village Troll
SS RRR's Avatar
Only problem I've had with my Strange 12-bolt in the 13 years I've owned it are the spider gears in the HD carrier breaking twice at the track. This is after about 20 outings within that time frame. Lots of 1.70 60' launches and a hand full of sub 1.6 in a full weight car as well as countless launches on the street with Nittos FWIW.
Old 01-20-2013, 03:33 PM
i'll post pictures tomorrow..got the gears out and housing cleaned up. The pinion gear had half the teeth gone and the ring was evenly chewed up all the way around. Had to order a new pinion nut and will put it back together with the 4:10's tomorrow.
Old 01-20-2013, 03:38 PM
cleb's Avatar
unless you go easy on the 4.10's, you will more than than likely eat those gears up too.
Old 01-20-2013, 03:46 PM
Oh i know. But i have them already....so it will end up costing me 30 buck to fix it for now. I will have to get a good rear at some point....just no cash for that at the very second
Old 01-20-2013, 03:47 PM
and i won't be going easy on anything
Old 01-20-2013, 07:30 PM
nitrous2fast's Avatar
Get a solid pinion sleeve. Does make the rear noisy, but tends to make the gears last a bit longer.... IMO.
Old 01-20-2013, 09:59 PM
Rob94hawk's Avatar
Got a part #?
Was thinking of going with these 3.90's after they were REM polished and cryo'd.
http://www.summitracing.com/parts/mgr-g975390
Quick Reply: blew up the 10 bolt
