5.3L turbo with tune and build ?s
FIrst off I am putting a th400 behind the 5.3. BUt Im having issues trying to figure out what flexplate I need.
The block is a 05 and I hear different stories about flexplates and spacers.
SO what do I need to make this bolt up? I have a chevy th400 and will order a converter to fit the 5.3L Ls engine but what is needed to make this work properly? I would like to order this all today.
Next ? is Should the car be tuned with a MAF setup or Speed density on e85?
Huron Speed turbo kit
http://www.speedwaymotors.com/LS-Cra...ter,64394.html
I'm assuming your 5.3 had a 60e. Behind it factory so it should have a curved flexplate That's all you need
SO If I use that adapter up above can I use a flexplate that came off my buddies lq9 engine? He is not using that lq9 flexplate will it work with this sleeve, my engine and a th400?
If the flexplate is curved I believe you can use it. You just need the spacer. I think I have one somewhere in my garage. I also have a flexplate that would work if your not sure. If I have it you can have it for the cost of the shipping and a six pack of beer. The spacer and flexplate.
I would also have to look again but I think if you use a LS style convertor with the longer snout and you tell them it is for a TH400, I don't think you even need the spacer. I think you only need the spacer if using a TH400 convertor and NOT the LS style convertor. I would have to double check. I will look at mine tomorrow. My engine and trans are currently out of the car and apart. I also run a TH400 behind a 5.3. I used the stock flexplate and originally used the same convertor I had and so I had to use the spacer and modify the holes in the flexplate. Later I got a LS style convertor and don't believe I use a spacer anymore. I'll check and report back tomorrow.
With a curved flexplate use that. Spacer. Depends on what your buddy's lq9 is out of. Chances are it had a 65e behind it so it would be a curved flexplate. The only ls motors that had 80e behind it come with the flat flexplate with the factory spacer between the crank and flexplate.
From what I see this subject gets over complicated all the time. Here is your options.
#1 curved flexplate is for a 60-65e (300mm) converter. Use the spacer from speedway if you want to use a "old school" converter.
#2 factory flat flexplate with factory spacer only came with a 80e because the 80e is a "old school" non 300mm converter
#3. Have a converter built for for ls
Of course this all depends on if you have a th400 converter already that you was going to use. Just have to weigh your options and decide how much money you want to spend.
I am using a 5.3 and th350 in my mustang and using the factory flat flexplate with factory crank spacer from a 80e setup. Hope this helps you
Yeah. No spacer on mine. If you want to use your same convertor I can look for my old spacer. I would get a PTC convertor for a TH400 with an LS snout like I did. The convertor was a huge difference. My car ran a 100mph with my old convertor and 118mph with the PTC convertor. (1/8th mile) A whole lot less work. If you use your old convertor you will also have to modify the holes on the flex plate like I did. I had success doing it but several others wiped out bearings down the road.
i run a stock 6.0 flexplate/spacer/bolts in my th/glide swapped cars, with regular style small block converters.
some places will make your converter to fit the 60e bowed plate, you can also get spacers from places online etc...
honestly if you are gunna get a converter ask the place building the converter what your options are and go from there.
