LT1 Dying on the interstate?
I have a 94 Z28 with the following mods: cold air intake, gasket matched intake, shaved and ported heads, cc503 cam, tuned by pcmforless. She has 147k on the clock.
Yesterday on my way to class, I down shifted and gave it a little gas to get around a slow driver and for about a half second the car died, and immediately picked back up and carried on fine the rest of the trip.
Today I was leaving class and had been on the interstate about 10 minutes and the car died again, but did not pick back up. I coasted to the shoulder, tried to crank and got nothing. I popped the hood, looked around, saw nothing appearing loose. Tried cranking and she cranked right up and I went home with no more issues.
Anyone have ideas as to what could be causing this? I'd hate to end up stranded, especially when I have a presentation due tomorrow night.
It isnt throwing any codes. I suppose it could be the fuel pump, but in my experience there has always been lack of power and sputtering prior to the fuel pump dying. I could be wrong there, but that's just been my experience.
Could it possibly be the ignition module or optisppark causing this? I hate to start replacing parts to track down the issue. Like I said, it could be the fuel pump, but I would assume the fuel pump would not go out all at once.
Update: I was under the hood and found a yellow wire going to the MAF that has been broken, but electric taped together. I recall bumping that when I was undet the hood on the side of the road. The wire was twisted together but seems lose. Maybe it's just a bad connection?
Juat went down the road, it cut off twice within 4 miles, everytime Its cut off has been around 2000 rpms or more. Almost like it's flooding out or something. The first time it did it tonight it cranked right up after a few seconds, but idled at 2k for a few seconds. The second time I sat for about 3 or 4 minutes before it cranked back up. I can hear the FP priming up when I turn the switch.
It definitely sounds like you're losing spark... I would guess that the culprit would be that MSD opti. check the pigtail connecters from the module to the opti, its possible one of them came loose. I've heard this is a commonly overlooked issue with those MSD systems. Other than that, do a spark test on all your wires. That's just what I would start with
93 TA M6, CC stage 3 clutch, freshly built trans, AC delete, CAI
There's a ton of forums here about opti replacement and troubleshooting as well as known issues with the MSD opti and coil.
