I have a 4th Gen Electrical Question
Only thing to do is pop out the switches and test power topower out when selected.
If power is available, and no power out, bad switch.
Test the return side the same way.
Check the door jam wiring. have seen this on all makes an models. Pull the rubber boot back in the door jams and check for broken wires. They will randomly make contact and work till you open or close the door. Hope this helps!
Ok guys i'm failing to see anything wrong with my BCM
I tried my 99 Firebird BCM in it, didn't fix the problem. Everything that normally works still worked with it.
Intermittent passenger window,and radio. They only work when they are BOTH working. I have yet to see the driver window work under any condition.
