383 stroker how much spray
Good luck getting everything you need for 600. Is your car a stick or auto? If stick and this is your first Nitrous run I'd get a progressive controller, it's easier for new guys IMO. Also you need an ignition box like stated above. If you can hook everything up yourself you'll save a pretty penny.
I have had 3 cars on tha bottle.
It's a 6speed car
I will do the install myself
And I can pick up kits off of local forums pretty cheap and add a few small things I can get away with between 600-800 I also have a few odds and ends laying around the kit isn't the problem
And I'm going to spray
So how much could I spray safely
I know it has Hastings rings but never wrote down the specs
I'm not asking for much Maby a 175shot
It's a 6speed car
Depends on the quality of the build and parts alone tell us little about that.
On a stock engine hell yeah it can be safe.
On a stroker with chinese parts and built by someone who sounds to have chosen displacement over head porting, I wouldn't try it. Then throw in the cam choice again another negative to my level of confidence.
If the heads are ported that is a positive bump in my confidence but seeing as you didn't state it up front and then didn't answer the question you are painting an unpleasant picture.
"nitrous cam" doesn't matter till a bigger shot, most folks seem to agree 250+ then you need to look at a "nitrous grind".
I have seen a few guys fail at coming up with "nitrous" cams for little 150-200 shots, hurt NA power enough to offset any potential gains on the jug.
You should be alright. Ive been running a 150 shot with progressive controller for over 2 years on a bolt on only lt1. So assuming your builder had half a brain you should be more than fine with 200 shot and right tune.
