383 stroker how much spray
Do you have an ignition box?
Are you going to change the plugs?
What rings are in it?
What's the part number on the pistions?
How much do you want to spend?
Do you want to run a progressive?
It's a 6speed car
I will do the install myself
And I can pick up kits off of local forums pretty cheap and add a few small things I can get away with between 600-800 I also have a few odds and ends laying around the kit isn't the problem
And I'm going to spray
So how much could I spray safely
I know it has Hastings rings but never wrote down the specs
I'm not asking for much Maby a 175shot
On the heads are they as cast or ported.
On a stock engine hell yeah it can be safe.
On a stroker with chinese parts and built by someone who sounds to have chosen displacement over head porting, I wouldn't try it. Then throw in the cam choice again another negative to my level of confidence.
If the heads are ported that is a positive bump in my confidence but seeing as you didn't state it up front and then didn't answer the question you are painting an unpleasant picture.
I have seen a few guys fail at coming up with "nitrous" cams for little 150-200 shots, hurt NA power enough to offset any potential gains on the jug.
