Camaro/Firebird Spohn 82-02 Lower Control Arm Relocation Brackets
Category: Steering & Suspension
Price: $40
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): IL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4
LS Engine?: Non-LS Part
$40 plus shipping
Spohn's description says:
Repositions your instant center by lowering your control arm angle for increased traction and anti-squat. Lowers rear of control arm up to 3". This product is a must for lowered vehicles to correct your suspension geometry. Lowering your vehicle alters the LCA angle putting the rear of the LCA higher than the front of the LCA, this causes massive wheel hop and traction loss.
NON-LOWERED vehicles will also see a dramatic increase in traction by lowering the rearward angle of the LCA with our relocation brackets. The lower mount holes are placed in the arc pattern of the OEM length LCA. Therefore allowing a non-lowered F-Body to drop the rear LCA angle and NOT require a longer than OEM LCA. All geometry is correctly maintained. The anti-squat performance is providing most users with a full .10 or better 60' reduction!
Brackets are Laser-Cut from 3/16" cold rolled steel using state-of-the-art CAD/CAM technology for precision tolerances.
Note: For installation on stock rear or Strange Engineering 12 bolt rear
