Finally 12mm to 3/8" NPT water temp adapter.
Old 01-25-2013, 07:28 PM
brian_wms's Avatar
Default Finally 12mm to 3/8" NPT water temp adapter.
Just had share my purchase out ebay. Somebody finally thought about making and adapter for the guys that have the 3/8 water temp. sensor. Hope this helps.
EBAY LINK
Old 01-25-2013, 07:39 PM
fat tony157's Avatar
Looks like a pretty good solution, but I have a feeling it will give an inaccurate reading. I'm currently working on a set of gm 3/8 npt temp sensors that I am turning down and threading for the LSx 12x1.5mm. Ill make a thread when they are done.
Old 01-25-2013, 08:01 PM
brian_wms's Avatar
For the price it's real good for me. I can keep all my factory gauges. So thats a plus for me. Temp should be okay, want be off my much.
Old 01-25-2013, 08:12 PM
Docked Wage's Avatar
That's quite a ways out of the main stream but other than being slow to respond it should work fine when everything heats up around it and transfers the heat in.
Old 01-25-2013, 08:15 PM
BobKovacs's Avatar
That thing is so damn long, the sensor may rub the fender well.
Old 01-25-2013, 08:22 PM
billyflantos's Avatar
i drill and tap my waterpump...
Old 01-25-2013, 09:00 PM
ls1nova71's Avatar
Doesn't seem like it would be too accurate to me either. I just drill and tap the passenger head. (Makes you not want to be my passenger. )
Old 01-26-2013, 08:35 AM
Pop N Wood's Avatar
LOL. Took me a moment.
If you throw a belt it will take so long for that thing to respond you might as well go without it.
Drill and tap the block heater plug. You can get 1/2 NPT that way
Quick Reply: Finally 12mm to 3/8" NPT water temp adapter.
