2008 4.8 truck engine into 1959 chevy apache with nova subframe 68-74
Truck pan is sitting on the crossmember. Have D.D. mounts that mount on to the clam syle mount. what oil pan should i get that is not as deep in the front. Or do i need to cut the crossmember and channel it. PS i should let you know i need the engine to drop down at lest 3/4in to get the bolts to go threw the mounts. Any info will realy help thanks.
F body pan is the narrowest in front followed by the mast pan. You may need to raise the engine by adding a spacer below the mount on the frame or cut out a section of the crossmember.
+1 on the F-body pan. it has the best clearance on the front part of the pan as compared to all of the other OEM pans.
The best suggestion I can give you is to move the Frame mounts.. add spacer as needed (providing you have room to raise the engine/trans).
I would bolt the DD plates to the engine, Clam/engine mounts and frame stands all together. Then drop the engine in, add spacer if needed, mark the frame stands on the X-Member and be done with it....!
You might just need to enlarge the holes or wrose case, drill new ones.
BC
BC
not sure if it works specifically but i have a corvette "bat wing" pan that im selling. see if maybe that will fit. there are threads out there with all the measurements of the pan.
