Belt Squeal Issue?
Old 01-28-2013, 09:21 AM
aaron_douglas's Avatar
Default Belt Squeal Issue?
Not sure if this was the correct place to post, but I've been having some belt squeal issues when it's cold or wet outside, and I'm pretty sure it's the serpentine belt or belt tensioner. I want to replace these, but I'm not for sure which belt to purchase. I planned to purchase a gatorback as I've heard good things, but I get several different results when I look it up. Anyone know exactly which gatorback to buy for a serpentine?
It's a 2001 Pontiac Trans Am. I think it's the serpentine because the squeal increases with RPM, and turning on A/C, etc. doesn't affect it. Though it only does it when cold or humid outside, so I'm not sure what's up there.
Old 01-28-2013, 09:33 AM
LS-ONE_DAY's Avatar
These should be the proper part numbers for right length belts
Goodyear 4040410 Gatorback Poly V-Belt - A/C drive belt?
Goodyear 4060790 Gatorback Poly V-Belt - Serpentine belt
Amazon, local parts stores, summit, etc
Old 01-28-2013, 09:36 AM
Cool thanks. I also should have asked, will any belt tensioner for the LS1 do? I saw some on eBay like the Dayco 89146, just wondered if it really mattered. First time replacing a pulley or belt.
Old 01-28-2013, 10:07 AM
LS-ONE_DAY's Avatar
That I'm not sure on, I would imagine so but I'll have to defer to someone else. I've never replaced my tensioner either
Old 01-28-2013, 10:16 AM
Alright. I had heard 90% of the time it was a pulley, not a belt when there was squealing, but the car has about 120k miles on it so I figure I'll replace the belt anyway either way. If the squealing doesn't stop after the new belt, I'll worry about the pulley. Thanks for the help.
Old 01-28-2013, 11:24 AM
kissmy99ss's Avatar
I have this exact problem, mine only squeels when its wet/cold/humid outside. then once the car warms up, normally about 6 miles worth of driving, the squeel stops.
Old 01-28-2013, 11:28 AM
MMWS6's Avatar
Check allignment marks on tensioner. If the tensioner is all the way or close to the end of travel, then get the gator belt/s. If they are not stretched yet according to the tensioner marks, you may be into a tensioner along with the belt/s.
Old 01-29-2013, 11:33 AM
TheBlueKnight's Avatar
When mine was doing the same thing as yours it ended up being the belt. Threw a gatorback on their and the squeal was gone. Give that a try first before doing anything with the tensioner.
Old 02-15-2013, 02:30 PM
mrhtl's Avatar
If all else fails rubbing a small amount of bar soap on the contact side of the belt, the kind you bathe with gets rid of squeals for a good period of time.
Quick Reply: Belt Squeal Issue?
