Shyt ... while cleaning off the head gasket with a scotch brite bad I ......
Went a lil low in one spot tward the end of the block (tward the front end ) ... It nothing noticable to the eye but if you rub your finger accross it you can barly feel it .... So is my block screwed or will the gasket compress enough to seal it .... Its not right next to the cyl or a water jacket
thanks
thanks
I am gonna use the stock type , it should compress enough to seal it up ... just pisses me off that i got in a hurry , hopefully its not a costly mistake
Originally Posted by BTL FED
If you are running stock type graphite gaskets it will prob be fine, if you are running MLS (Multi-layer steel gaskets) you MAY have a problem
Originally Posted by BBADWS6
Use the felpro gasket, they are the thickest available, i think they are .040 thick.
Shawn
