camshaft degreeing question (results show retarded 1 degree?)
I got the following results when degreeing my cam last night. I'm just curious if people would run it as is dot to dot, or if it's worth advancing it a tooth. Or if there's a margin of error that I'm close enough not to mess with it.
Comp Cams 4796 degree kit. Wheel shows 10* on each side of TDC indicating I'm dialed in at TDC:
gauge zeroed off the lobe:
indicator at max lift:
indicator zeroed at max lift:
.050" on the opening side:
degree wheel reading .050" on the opening side:
.050" on the closing side:
degree wheel reading .050" on the closing side:
my measurements indicate the cam is retarded 1*
100 + 126 = 226 / 2 = 113
the intake center line on the cam card is 112
basics specs on the cam are 226/238 115+3, so right now it's basically installed as 226/238 115+2?
As others have posted you will not see 1 degree. You asked about advancing one tooth, this will move it quite a number of degrees (just guessing without doing the math but I would say 8 or so).
The chain is a new katech c5r chain and it's nice and snug, it runs right against the dampner when rotating.
