What all do i need to install a LT4 hot cam on a 95 LT1 stock motor?
FIrst off im going to apologize for my lack of knowledge about intricacies of internal motor mods. And also, ive googled this for the past couple hours. Almost found an answer... But for some reason guys respond to the question with questions not answers. So...
Im getting a stock LT1 t56 DD for cheap. Its not intended to b a money pit. But i want a little extra out of the motor. I want to know exaxtly what i'd need to buy/ modify in order to install the LT4 hot cam kit? Ive heard some have had trouble with the valve covers rubbing the rocker arms. And i know the 95+ lt1's have the different timing than previous motors. And they kit dont come with roller tappets. (dont know what those are) and some say the springs are weak that come in the kit. Also where is the cheapest place to get this kit? I think samtaylor.com has the kit for $489. Or is there a possible better set up (with stock bottom end) thats in the same price range. I plan on porting and polishing the Heads, Intake and TB. Upgraded exhaust, plugs and plug wires. Thats about it. So theres my intentions, im welcoming instructions, or suggested revisions.
Before you do a cam you should do full bolt ons so you can even get what you want out of the cam. Do intake, exhaust, and you will definitely want to upgrade your rockers/ springs. Doing that will let the cam breathe.
Okay i didnt want to get into the small detail, but ive got about 2000 in my tax return coming my way in a couple weeks. So to further explain, the car has long tubes, and im going to do true duals and do some 2 chamber race mufflers dumped just before the rear axle. I will be doing all these things with a small time frame. What i wanted to know was not what other modifications would optimize the cam, what other parts do i need to buy/install inorder for the cam to be put in and be able to start the car without serious damaging something internally. Ive continued researching and have found some info, but would like sone input with ppl who have experience / knowledge from this kit.
If you don't believe me then believe the physics.
http://www.camaroz28.com/forums/exha...t-info-371087/
I thought since the car wasa 95 that the timing set was good to use? They changed it in 95. 93 & 94 used a different one which has to be swapped in order for the new cam to work. Or do you have a different underlying reason for the advice? Id like to try to understand and absorb everything i can here. And as far as the oil pump, is that a necessity for a "baby cam"? I wouldnt have thought the current one would be unsufficient seeing there is not a drastic change? But hey, i love learning new things!
So ive added a new timing set and oil pump to the wish list. Lol ive also decided to go with the cc306 cam, beehive springs (havent yet figured out which spring rate to get), upgrade to some hardened push rods, and go with the comp cams pro magnum 1.6 rrs. They have a slef aligning set so if i chose them would i also need alignmetplates then? Or no? Also ill want the 3/8 stud ones right? Not the 7/16 with stock heads that is. I also like to know if this set up compliments itself well and if there are any mismatches or leak links you see that i would need to correct. Keep in mind the intake, TB, and heads will be ported and polished. And finally tuned.
Are you confusing the oil pump drive with the oil pump? The oil pump drive bolts into the lifter valley. Because GM used most of the traditional SBC architecture when they designed the LT1 it needs what is essentially the bottom of a regular distributor to drive the oil pump drive shaft.
You don't need to change the oil pump itself when replacing the camshaft.
Pick up this book, it covers all the basics and is worth the money.
http://www.summitracing.com/parts/hpb-hp1393/overview/
Read your own article, it says back pressure reducing torque is a myth. Only thing you would feel different would be until the computer adjusts for the increased flow. Needing back pressure for torque is total and COMPLETE MYTH. However, adding scavenging can increase power, by using the pressure of one exhaust pulse to pull out the next pulse.
