what pulley do i need now going to sdce
picked up an 8 rib sdce setup and right now i have a 6 rib setup from procharger . so its got the 6" bolt on crank pulley and a 3.0 pulley . i was making 6 lbs max and tapering to 4-5 . i assume belt slip . So doing the math with a 7.25 pulley on the crank with the sdce i come out with a 3.625 pulley . That cant be right. can it . I have a stock engine , ls6 intake and headers thats it , shifting at 6k . I must need a much larger pulley than that ?
no tool , guy said a screwdrivers works fine . ill find out
anyways i was cross multiplying to figure it but to stay the same i think now i need a 4.25 . a 6 crank with a 3 pulley to a 7.25 with a 4.25 crank keeps its the same . does sdce or anyone have a breakdown of belt lengths either .
