LS1 Brake Upgrade Question
Just to make sure I get everything I need and do it right the first time...
What else is required to do this mod besides 98-02 spindles?
Is it better to buy the calipers, rotors, and pads separate?
Will 98-02 SS lines work?
You will need the 98-02 calipers, rotors, and pads if that is what you are asking. Of the top of my head i dont remember what hose's i used on my car. Somebody will come in and answer that I am sure.
Ok thank you. I was under the (wrong) impression that SS lines were longer.
What I meant by buying them separate was use the calipers that came with the kit or source them elsewhere (aftermarket,parts store,etc)
I picked up a kit containing all the parts I need out of the parts forums, just missing one caliper bracket.
Village Troll
They are more adapters than relocation brackets. You have to sawzall the ears off the spindles before you can bolt up the brackets. You can use LT1 brake lines that go from the calipers to the hardline, but they are a bit on the tight side if you turn the wheels to lock. It's been suggested to use the LS1 f-body brake lines instead. C5 lines are too long and may end up getting bound up in the wheel/tire.
Go to kore3.com thats where i bought my C5 brake conversion. They have everything needed, can be bought as a kit or seperate. The kit i bought comes with detailed instructions. Awesome site.
Thanks guys. I am only doing and already bought the Fbody fronts but will keep my stock spindles just in case a C5 upgrade is in the future.
Also the complete setup will be done for under 300 with all new pads and rotors so I believe that is a good price.
WS6Store sells a nice LT1 to C5 conversion length Stainless brake line kit for $78
http://www.ws6project.com/user_stor/...t-front-only-/
