How are the 454's (and bigger) holding up ?
Old 02-03-2013, 09:09 PM
SPDMETL's Avatar
Default How are the 454's (and bigger) holding up ?
I see so many works/won't work discussions about long stroke motors, I'm hoping those of you who have them will chime in. Thanks!
Old 02-04-2013, 07:34 PM
SPDMETL's Avatar
Wow, hot topic!
Old 02-04-2013, 08:33 PM
ramairetransam's Avatar
no one knows , the people who can afford them probably dont drive their cars much anyway . I mean if your gonna drop a bunch on your engine your more than likely not putting 10k miles on it a year.
I dont think their are a ton of guys on here with 454 and larger ls engines . Maybe 20 max .
Old 02-04-2013, 08:49 PM
Blackpanther99's Avatar
I agree with ramairetransam... People who have those blocks probably dont drive thrm much at all, probably just hit the track often.
Old 02-05-2013, 06:25 AM
Cam02ss's Avatar
Built a solid roller 440 and it's for racing, no street use at all
Old 02-05-2013, 06:41 AM
lemons12's Avatar
I know what you were getting at, but I'm going to guess that there are way more large displacement guys than that.
Old 02-05-2013, 08:44 AM
RoadconeTuning's Avatar
theres def a ton of big cube LS motors out there but they are in race cars... if you want to go over 450cubes you're generally better off with a big block, it'll be cheaper and last longer
Old 02-05-2013, 02:18 PM
93formto98T/A's Avatar
True. I'm sure there are dozens of 454ish LSx guys here on tech. I just installed my 470ci solid roller LSX and it will be strictly a street car. However it won't be a DD.
Old 02-05-2013, 04:56 PM
WKMCD's Avatar
That is such a stupid hot car!
Doesn't hurt that it has one of Shawn's motors in it.
Old 02-05-2013, 07:29 PM
Sawzall and Welder Mod
Whistler's Avatar
4.250 stroke I assume? Makes for insane piston speeds with a solid roller at high RPM! That's got to be a handful to keep straight
Old 02-07-2013, 07:50 AM
Thanks. Yep Shawn is a stand up guy. Glad his engine is in my car.
Yep 4.250 stroke. 8K rpm solid roller, HUGE cam, 12.5CR, Dual 4bbl TBs should be all of 700rwhp thru an auto on pump gas- yes, pump gas. It was built to handle a 500 shot on top.
Old 02-07-2013, 08:17 AM
WKMCD's Avatar
What intake manifold are you running? Any pics of the setup?
Old 02-07-2013, 09:36 AM
LPE 403's Avatar
x2
(fingers crossed....Marcella....Marcella....Marcella)
Old 02-07-2013, 10:17 AM
ptero's Avatar
Not much history to go on from me but I've had my HKE built, LS2/7, N/A, pump gas, 454 running right at a year now. ~1K miles & 40+ hits on it. Last time out it ran it's quickest time (9.993); there's no evidence it's "fading". It's far from a DD but is a street car. Certainly not an engine I would pick for a DD
Old 02-07-2013, 10:18 AM
Originally Posted by LPE 403
x2
Not Marcella, even better. It's a one off piece by VA Speed at the tune of $8K. It's basically a hi-Ram/sheetmetal intake which has been widened to bolt directly to the heads in a tall deck application.
Old 02-07-2013, 10:49 AM
WKMCD's Avatar
Old 02-07-2013, 11:03 AM
Pic already posted. That's all I got for now. The car is undergoing a major face lift and new paint.
Old 02-10-2013, 11:33 AM
ringram's Avatar
Im at 40,000 miles in my 440 Darton.
Valvetrain was not set up right first up from vendor. Cam got trashed.
Rebuilt better and going ok so far.
Goal is 200,000 with any luck.
It eats a bit of oil. I dont think the hone job or piston to bore setup was done right. But its tolerable. Next time, Id go 427 to keep parts off the shelf. But no hesitation in doing a stroker again. OEM config..
Old 02-12-2013, 02:56 PM
Orange Juice's Avatar
probably not more then 2000 miles on mine. Only issue is a blown rear main so I've installed a vacum pump. Since the pump install I haven't had a chance to drive it because of a drive train issue. Hopefully have all the little bugs out of the car this spring and finish off the SD tuning with the 102/102 set up and better exhaust.
Old 02-12-2013, 03:36 PM
Stage7's Avatar
I love your drive. Your build just gets sicker and sicker. I love it.
HKE 468 in my C6. Not many miles but it never burned a drop of oil in 2k miles.
My new 468 setup in my SLC won't be enough of a daily driver to really validate issues. I've gone with a 6 stage dry sump so I doubt I will have any oil consumption issues regardless.
I'm considering a 454 for my daily driver (G8). I'm pretty comfortable with the prospective reliability...
Quick Reply: How are the 454's (and bigger) holding up ?
