new 231 237 cam
new 231 237 cam
i've got a 99 camaro SS. i want to put in a 231 237 cam. and i wanted some suggestions on where i should order it from , what else i need to get with it and an estimate of how much it will cost.
!LS1 11 Second Club
Texas Speed and Performance. ------>
You'll need a crank bolt and other miscellaneous items involved with a cam swap, but most important, you'll need upgraded springs (Comp 918's at the very least, but go with dual springs for peace of mind).
Thunder Racing has a complete cam swap package. I'm sure TSP can hook you up as well.
Got mine from TSP. I think they have a special on it. Around $300. This cam likes a good set of ported heads and a free flowing exhaust. I would also get hardened pushrods if you are going with just a cam. And of course, a good set of dual valvesprings. Crane or Patriot duals.
!LS1 11 Second Club
Originally Posted by Helix427
also what is the driveabilty like with this cam.
Check the vendors feedback section. I think you will find that Texas Speed has a great reputation on the boards and out on the street. They have about the best customer service one could ask for....and as we have seen in the past, that can make the difference between a customer and a return customer.
LS1TECH Sponsor
the powerband of the 231/237 cam is pretty high in the rpm range...higher gearing will allow you to get into that powerband quicker and stay in that powerband longer. You will loose a couple mpg on the highway(maybe) thats if your always driving in 6th gear now 6th will actually become usable to you. Around town youll be in 4th gear or maybe even 5th instead of 3rd gear cruising around.
lata
Bill
lata
Bill
LS1Tech Premium Sponsor
The 231.237 is a Texas Speed camshaft You can run a search for all kinds of different setups using this cam in the dyno section. It is on special right now in the sponsors section with or without springs!!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
