new 231 237 cam
Old 04-18-2004, 12:52 AM
Helix427's Avatar
Question new 231 237 cam
i've got a 99 camaro SS. i want to put in a 231 237 cam. and i wanted some suggestions on where i should order it from , what else i need to get with it and an estimate of how much it will cost.
Old 04-18-2004, 12:59 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Texas Speed and Performance. ------>
You'll need a crank bolt and other miscellaneous items involved with a cam swap, but most important, you'll need upgraded springs (Comp 918's at the very least, but go with dual springs for peace of mind).
Thunder Racing has a complete cam swap package. I'm sure TSP can hook you up as well.
Old 04-18-2004, 01:02 AM
goinbroke's Avatar
Got mine from TSP. I think they have a special on it. Around $300. This cam likes a good set of ported heads and a free flowing exhaust. I would also get hardened pushrods if you are going with just a cam. And of course, a good set of dual valvesprings. Crane or Patriot duals.
Old 04-18-2004, 01:36 AM
Helix427's Avatar
also what is the driveabilty like with this cam.
Old 04-18-2004, 01:59 AM
!LS1 11 Second Club
It's very liveable with good tuning. Good tuning is crucial, along with the correct gears and/or toque converter to match.
Old 04-18-2004, 05:02 AM
Pewter_LS1's Avatar
what would be the correct gears?
Old 04-18-2004, 05:11 AM
Toonz's Avatar
I'm considering this cam as well.... wanting to match it up with some 4:10's in my M6. Gotta get some new valves first.... damn springs went and bent one.
Old 04-18-2004, 09:53 AM
!LS1 11 Second Club
4.10's match up well on an M6.
Old 04-18-2004, 11:55 AM
Ponyhtr's Avatar
Check the vendors feedback section. I think you will find that Texas Speed has a great reputation on the boards and out on the street. They have about the best customer service one could ask for....and as we have seen in the past, that can make the difference between a customer and a return customer.
Old 04-18-2004, 01:17 PM
Helix427's Avatar
what is the importance of using 4.10 gears on a m6 and how does it affect the driveability?
Old 04-18-2004, 01:50 PM
LS1TECH Sponsor
foff667's Avatar
the powerband of the 231/237 cam is pretty high in the rpm range...higher gearing will allow you to get into that powerband quicker and stay in that powerband longer. You will loose a couple mpg on the highway(maybe) thats if your always driving in 6th gear now 6th will actually become usable to you. Around town youll be in 4th gear or maybe even 5th instead of 3rd gear cruising around.
lata
Bill
Old 04-18-2004, 06:37 PM
master of the "jack"stand
ChevyWeatherman's Avatar
I have 3.42s with this cam and it is very driveable. It may not be optimal for track use, but getting around town is certainly no problem.
Old 04-18-2004, 07:19 PM
LS1TECH Sponsor
foff667's Avatar
its better than my 2.73's hehe
Old 04-18-2004, 07:54 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The 231.237 is a Texas Speed camshaft You can run a search for all kinds of different setups using this cam in the dyno section. It is on special right now in the sponsors section with or without springs!!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
