89 Coupe part out :(
Category: Accessories
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, 04-06 Pontiac GTO
Location (State): TX
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
*COMP Cams LSR Series hydraulic roller camshafts Duration 285/293, Lift .621/.624, Lope 113 RPM Range: 2,200-7,200 ($350.00)
COMP Cams Keyway Adjustable Billet Timing Sets 7106 ($100.00)
(Fresh) Th400 with jw LS1/TH400 JW Ultra-bell build for a 1000+ Hp i purchased from daniel044
(new) Circle d billet 3500 converter 350/400 Ls pro series stage II 258mm 2B Built for a 1000+ Hp
(used) tci sfi flex plate ($2200)
(New) Psi conversion harness standalone w/t56 or th350/400 (DBC)
Pcm w/ tune with vats removed
with fan control relay kit $ 770.00
MELLING OIL PUMP $110.00
Also have a Ls2 i had bought, that had some damage repaired where the bell housing bolts up, I was told it was ok and had a professional weld it back but it looks like he missed some spots but still leaks a little oil. Just had the motor hone, new cam and crank bearing, comp cam and arp 2000 bolts instilled in the rods.
I may sell the whole car if the price is reasonable, it was almost ready to be started all part are new, a lot of parts it didn't list like new magnafuel pump, 95lb injectors, 80mm Borg Warner turbo, turbosmart 50mm wastegate and bov, Kirkland racing seat, build rearend with 31 spline moser axles and more. Make me a offer, a real offer btw
