3" T6 Turbo Merge Question/Request for pics
Old 02-09-2013, 04:01 AM
MattKatz's Avatar
Default 3" T6 Turbo Merge Question/Request for pics
I need to make a dual 3'' merge for a T6 undivided Flanged Turbo.
Looking for options, ideas and pics of what you have, know of, or have made.
Any info is appreciated.
Thanks in advance.
Last edited by MattKatz; 02-09-2013 at 04:04 AM. Reason: Because I have fat fingers that make me look like I cant spell
Old 02-09-2013, 06:31 AM
LS1NOVA's Avatar
Saw your thread on YB. Do 2.25 or 2.5. Its plenty for what your doing. Its not like an NA build, you want to keep the pipes small to keep the velocity fast.
Old 02-09-2013, 06:53 AM
MattKatz's Avatar
Thanks for your input....But I think Ill stick to my plan. I dont want any restrictions....and since its on a Drag only vehicle....Id say itll work fine in a 3" application. But Ill take pics of 2 or 2.5'' as well....Ill just apply it differently if I see something I like.
Old 02-09-2013, 07:04 AM
LS1NOVA's Avatar
Do what you want but you'll actually have BETTER performance with smaller pipes.
Old 02-09-2013, 07:17 AM
MattKatz's Avatar
I might....But I cant see how considering Ive been told I will be restricted as it is with the Turbine....so I definately dont want the piping to be restrictive at all.
Old 02-09-2013, 07:29 AM
dschmittie1's Avatar
3" cross over is a bad idea. Why do cars making 2500+ hp only run 2.5" crossovers.
Here is a good read
https://ls1tech.com/forums/forced-in...over-pipe.html
Old 02-09-2013, 07:30 AM
3" cross over is gonna make the turbo spool slower and have slower responce.
Old 02-09-2013, 07:45 AM
Restricted User
98Z28CobraKiller's Avatar
OP, another good way to look at it is that 2 2.5 pipes merge perfectly into a T6 flange once you square the ends.
So using 2 3" pipes actually gets you a bottle neck at the turbo. Also, much of the turbo magic is the heat energy. Larger plumbing = more surface area = more lost heat energy.
But if that still doesn't convince you, well, some people need to learn the hard way.
Old 02-09-2013, 08:06 AM
dmaxvaz's Avatar
I will be using 2.25 pipes with my 390ci, dual wig's and a t6 turbo (1.32 hot side), with my build.
Old 02-09-2013, 08:22 AM
LS1NOVA's Avatar
Whats the quickest AWD TBSS in the nation run?
Old 02-09-2013, 08:32 AM
MattKatz's Avatar
10's @ 4900+ pounds....and thats not what this is for.
(and for the record...Im only second Quickest now, need to update my SIG i guess)
I like how youre trying to be a smartass though.
Old 02-09-2013, 08:50 AM
67Firebird455's Avatar
You're wasting energy, and efficiency using that big of a pipe. Wasn't the limitation for 2.25 pipes something absurd like 1800-1900BHP?!
Old 02-09-2013, 11:07 AM
Camaro9969's Avatar
Here's a picture of my 2.5 with the merge into a true divided flange. Twin tials
Do 2.5" Max......
Old 02-09-2013, 11:32 AM
JAX04's Avatar
Here is a good read
And when your done reading that thread, follow the link to the thread on YB, "**** it, turbo charging 102....."
When you've read that, then come back and say, "****, i guess all these people were actually trying to help me."
Best of luck
Also, Guys, help me out here, who was the guy with the black murdered out ws6 370" with a gt91? or some big turbo? He rebuilt his turbo kit because he stayed the course with 3" and had some of the worst spooling trouble. At the track...
Old 02-09-2013, 01:19 PM
GueSS Who's Avatar
3 in is way to big. redo your plan
Old 02-09-2013, 02:56 PM
7 Second Club
Phil99vette's Avatar
2.5" here and I fully intend on making 2600hp at the crank
Old 02-09-2013, 04:09 PM
Taubr Unit's Avatar
I respect you doing what you want to do vs listening to all the cookie cutter stuff everyone else is doing. Here's my 2.5" merge to a t6 open flange..
Old 02-09-2013, 04:16 PM
Cam72aro's Avatar
ws666 i think was the black t/a that JAx was referring to. He did 3" and went down because spool was slow. Do what you want, but you are posting in an informative forum and looking for help. We are all suggesting 2.5 or 2.25.
Old 02-09-2013, 04:26 PM
7 Second Club
Little engine **** for you guys
Old 02-10-2013, 01:00 AM
I love engine **** Phil.
Quick Reply: 3" T6 Turbo Merge Question/Request for pics
