1.6 rockers 7/16 best option?
Hi guys,
I'm working on my forged 355 LT1 and I'm looking to upgrade my rockers.
At the moment I have proforms 1.6 3/8s.
I have fully ported heads 210, cam, V1 supercharger, 58tb, and some other mods.
My target is 550-620HP.
Looking for non self aligning ones and valve cover clearance is not an issue.
At the moment I am considering these:
PRW 1.6 7/16
http://www.ebay.co.uk/itm/1609398569...84.m1423.l2649
Scorpion Racing 1.6 7/16
http://www.ebay.co.uk/itm/3707503048...84.m1423.l2649
Comp Cams Ultra Pro Magnums 1.6 7/16
http://www.ebay.co.uk/itm/1408744275...84.m1423.l2649
I need a quality but don't really want to overpaid if there is no point.
Any feedback will be much appreciated especially from people who had these installed.
Thanks
PRW 1.6 7/16
Thanks
Village Troll
I am a firm believer of never skimping on the valvetrain regardless of the build.
^^^ Those IMO. Even the normal pro mags will do you just fine if they are less expensive.
I have already Competition Cams 4808 guide plates.
Hope these are good enough.
http://www.summitracing.com/parts/cca-4808-8
Once I have rockers I need to measure pushrod lenghts and get some pushrods.
Anything you can recommend for this set up?
Thanks
Thanks
A smart person understands valvespring in particular become a maintenance item with aftermarket cams, just because nothing is broken doesn't mean it is still working right.
Far as guideplates, whatever you use check to make sure the rockers are reasonably well aligned with the valves, most regular SBC PNs wont give you that.
I run the pro mags
Isky makes an adjustable pushrod guide works fantastic. Befor the adjustable guides my afr guides always let me bend pushrods - or maybe it was the rocker would slip off - in any case no problems at all after the Isky adjustable guides.
