camaro rack and pinion install
Old 02-17-2013, 05:42 PM
Double J's Avatar
Default camaro rack and pinion install
Hello, can anybody advise how labor intensive it is to replace DIY. Any special tools required? Do the front wheels need to be removed?
Thanks in advance
Old 02-17-2013, 07:28 PM
sjsingle1's Avatar
the hardest part is the drivers side bolt......you can lift the engine to clear bolt removal.......or you can cut it.......other than that its not hard
there are many threads on the subject
Old 02-19-2013, 12:45 AM
Always2Slow's Avatar
Buy a sawzall cut the bolt its a breeze besides cutting the bolt.
Old 02-21-2013, 12:21 AM
six2eight's Avatar
make sure when you reinstall it, put the bolt in up side down with the nut on top so you dont have to chop away next time.
Old 02-23-2013, 09:37 AM
J_O_E's Avatar
Yes, you should remove the front wheels. Need to unbolt the tie rod from the knuckle.
Old 02-24-2013, 10:54 AM
Double J's Avatar
thanks to all for responses, one more thing-i see they offer rebuild kits for R&P, is that a smart option$$ ? Do they require removal of unit or can they be fixed w/o going through whole removal process??
Old 02-24-2013, 11:26 AM
six2eight's Avatar
Given the lack of space it would almost seem easier to just buy a rebuilt rack and swap it.
Old 02-24-2013, 03:00 PM
garygnu's Avatar
I say use a small grinder and a cut off wheel to remove the bolt.use loctite on the new bolt.
Quick Reply: camaro rack and pinion install
